[GeoNode-users] Best way to install geonode
Annalisa Schiavon annalisa.schiavon at gmail.com
Thu Oct 25 03:27:01 PDT 2018
Please someone may confirm that installation by deb packages, with
ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
What advantages does have VM Setup with VirtualBox installation (
http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
And than the installation step by step described in
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
If I want to changes logos, colors and texts, is it recommended install
geonode-project and create a template, in similar way than once? Because in
https://github.com/GeoNode/geonode-project I find instructions only for a
Python virtual environment.
Thank you for any hint.
Annalisa
Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
annalisa.schiavon at gmail.com> ha scritto:
> Hi all.
> What is the best way to install geonode on Ubuntu for production,
> currently?
> Now we have geonode 2.4 working on ubuntu 16.04, installed via apt-get,
> following these commands:
> sudo add-apt-repository ppa:geonode/stable
> sudo apt-get update
> sudo apt-get install geonode
> Then I had installed geonode-project for a few changes in logos, colors
> and so on:
> django-admin startproject geoportale20 --template=
> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
> sudo pip install -e geoportale20
> There are some procedures to migrate data from 2.4 to 2.8 (jumping the 2.6
> release)?
> Thank you,
> Annalisa
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/e1eaf9f9/attachment.html>
More information about the geonode-users mailing list
