[GeoNode-users] Best way to install geonode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Oct 25 03:41:24 PDT 2018
If you want to install geonode for development, I would suggest following
the procedure here
https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
If you want to start customizing your own portal (but still develop it), I
would suggest starting from a geonode-project template. In that case,
follow the instructions here
https://github.com/GeoNode/geonode-project#create-a-custom-project
Otherwise, you can virtual machines either using vagrant or docker. There
are several ways and configurations around that you might want to evaluate.
Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
annalisa.schiavon at gmail.com> ha scritto:
> Please someone may confirm that installation by deb packages, with
> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
> What advantages does have VM Setup with VirtualBox installation (
> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
> And than the installation step by step described in
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> If I want to changes logos, colors and texts, is it recommended install
> geonode-project and create a template, in similar way than once? Because in
> https://github.com/GeoNode/geonode-project I find instructions only for a
> Python virtual environment.
> Thank you for any hint.
> Annalisa
> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>> Hi all.
>> What is the best way to install geonode on Ubuntu for production,
>> currently?
>> Now we have geonode 2.4 working on ubuntu 16.04, installed via apt-get,
>> following these commands:
>> sudo add-apt-repository ppa:geonode/stable
>> sudo apt-get update
>> sudo apt-get install geonode
>> Then I had installed geonode-project for a few changes in logos, colors
>> and so on:
>> django-admin startproject geoportale20 --template=
>> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
>> sudo pip install -e geoportale20
>> There are some procedures to migrate data from 2.4 to 2.8 (jumping the
>> 2.6 release)?
>> Thank you,
>> Annalisa
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/5d08b7cb/attachment.html>
More information about the geonode-users
