[GeoNode-users] Best way to install geonode
Annalisa Schiavon annalisa.schiavon at gmail.com
Thu Oct 25 04:11:37 PDT 2018
Ok, thank you so much.
So you advise against the deb package installation, also if I don't think
to develop on geonode,  only to customize the look?
Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> If you want to install geonode for development, I would suggest following
> the procedure here
> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
> If you want to start customizing your own portal (but still develop it), I
> would suggest starting from a geonode-project template. In that case,
> follow the instructions here
> https://github.com/GeoNode/geonode-project#create-a-custom-project
> Otherwise, you can virtual machines either using vagrant or docker. There
> are several ways and configurations around that you might want to evaluate.
> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
> annalisa.schiavon at gmail.com> ha scritto:
>> Please someone may confirm that installation by deb packages, with
>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>> What advantages does have VM Setup with VirtualBox installation (
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>> And than the installation step by step described in
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>> If I want to changes logos, colors and texts, is it recommended install
>> geonode-project and create a template, in similar way than once? Because in
>> https://github.com/GeoNode/geonode-project I find instructions only for
>> a Python virtual environment.
>> Thank you for any hint.
>> Annalisa
>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>> Hi all.
>>> What is the best way to install geonode on Ubuntu for production,
>>> currently?
>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via apt-get,
>>> following these commands:
>>> sudo add-apt-repository ppa:geonode/stable
>>> sudo apt-get update
>>> sudo apt-get install geonode
>>> Then I had installed geonode-project for a few changes in logos, colors
>>> and so on:
>>> django-admin startproject geoportale20 --template=
>>> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
>>> sudo pip install -e geoportale20
>>> There are some procedures to migrate data from 2.4 to 2.8 (jumping the
>>> 2.6 release)?
>>> Thank you,
>>> Annalisa
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/6d259613/attachment.html>
More information about the geonode-users mailing list
