[GeoNode-users] Best way to install geonode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Oct 25 04:15:33 PDT 2018
Yes, absolutely. Currently, the deb installation is the most buggy and
unstable one.
It is worth notice that now GeoNode provides natively a way to customize
the interface, at least some part of it, without the need of changing the
files or the templates.
Take a look at the GeoNode Themes option on the Django Admin gui.
Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
annalisa.schiavon at gmail.com> ha scritto:
> Ok, thank you so much.
> So you advise against the deb package installation, also if I don't think
> to develop on geonode, only to customize the look?
> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> If you want to install geonode for development, I would suggest following
>> the procedure here
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>> If you want to start customizing your own portal (but still develop it),
>> I would suggest starting from a geonode-project template. In that case,
>> follow the instructions here
>> https://github.com/GeoNode/geonode-project#create-a-custom-project
>> Otherwise, you can virtual machines either using vagrant or docker. There
>> are several ways and configurations around that you might want to evaluate.
>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>> Please someone may confirm that installation by deb packages, with
>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>> What advantages does have VM Setup with VirtualBox installation (
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>> And than the installation step by step described in
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>> If I want to changes logos, colors and texts, is it recommended install
>>> geonode-project and create a template, in similar way than once? Because in
>>> https://github.com/GeoNode/geonode-project I find instructions only for
>>> a Python virtual environment.
>>> Thank you for any hint.
>>> Annalisa
>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>> Hi all.
>>>> What is the best way to install geonode on Ubuntu for production,
>>>> currently?
>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via apt-get,
>>>> following these commands:
>>>> sudo add-apt-repository ppa:geonode/stable
>>>> sudo apt-get update
>>>> sudo apt-get install geonode
>>>> Then I had installed geonode-project for a few changes in logos, colors
>>>> and so on:
>>>> django-admin startproject geoportale20 --template=
>>>> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
>>>> sudo pip install -e geoportale20
>>>> There are some procedures to migrate data from 2.4 to 2.8 (jumping the
>>>> 2.6 release)?
>>>> Thank you,
>>>> Annalisa
>>>> _______________________________________________
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/aa108499/attachment-0001.html>
More information about the geonode-users
