[GeoNode-users] Best way to install geonode
Annalisa Schiavon annalisa.schiavon at gmail.com
Thu Oct 25 04:28:34 PDT 2018
Thanks for the tip!
Annalisa
Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Yes, absolutely. Currently, the deb installation is the most buggy and
> unstable one.
> It is worth notice that now GeoNode provides natively a way to customize
> the interface, at least some part of it, without the need of changing the
> files or the templates.
> Take a look at the GeoNode Themes option on the Django Admin gui.
> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
> annalisa.schiavon at gmail.com> ha scritto:
>> Ok, thank you so much.
>> So you advise against the deb package installation, also if I don't think
>> to develop on geonode,  only to customize the look?
>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>> If you want to install geonode for development, I would suggest
>>> following the procedure here
>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>> If you want to start customizing your own portal (but still develop it),
>>> I would suggest starting from a geonode-project template. In that case,
>>> follow the instructions here
>>> https://github.com/GeoNode/geonode-project#create-a-custom-project
>>> Otherwise, you can virtual machines either using vagrant or docker.
>>> There are several ways and configurations around that you might want to
>>> evaluate.
>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>> Please someone may confirm that installation by deb packages, with
>>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>> What advantages does have VM Setup with VirtualBox installation (
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>> And than the installation step by step described in
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>> If I want to changes logos, colors and texts, is it recommended install
>>>> geonode-project and create a template, in similar way than once? Because in
>>>> https://github.com/GeoNode/geonode-project I find instructions only
>>>> for a Python virtual environment.
>>>> Thank you for any hint.
>>>> Annalisa
>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>> Hi all.
>>>>> What is the best way to install geonode on Ubuntu for production,
>>>>> currently?
>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>> apt-get, following these commands:
>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>> sudo apt-get update
>>>>> sudo apt-get install geonode
>>>>> Then I had installed geonode-project for a few changes in logos,
>>>>> colors and so on:
>>>>> django-admin startproject geoportale20 --template=
>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
>>>>> sudo pip install -e geoportale20
>>>>> There are some procedures to migrate data from 2.4 to 2.8 (jumping the
>>>>> 2.6 release)?
>>>>> Thank you,
>>>>> Annalisa
>>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/cc843f02/attachment-0001.html>
More information about the geonode-users mailing list
