[GeoNode-users] Best way to install geonode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Oct 25 06:48:25 PDT 2018
Hi Julierme,
please see my responses below.
"1 - can I make geonode-project my production environment? I meant run
GeoNode-Project as my production instance on the web."
Sure, but you will need to tweak a bit security options and settings in
order to secure and optimize your instance. Especially important are the
admin passwords and openid keys. This is valid in any case though.
"2 - do I need GeoNode Core to run together with GeoNode-Project?"
geonode-project makes use of geonode-core as a dependency. Until we do
final releases (2.10 and 2.8), meaning that packages will go on Pypi
repositories, yes, you'll need the geonode-core among the python deps.
"3 - GeoNode-Project can run independently, no need for GeoNode Core?"
geonode-project runs independently, but it still needs geonode as a
dependency. However by using it, you won't touch the geonode-core. This
will allow you to easily keep it up to date with the development version,
without clashes.
"4 - If I am not misunderstanding, the tutorial in here <
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode in a
Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
GeoNode version or upgrade it to GeoNode 2.9.x?"
The tutorial and the documentation in general is outdated. We are lacking
of resources and, unfortunately, we did not found time yet to cleanup it.
I'm very sorry about that.
We will try to do it when we start officially the release process.
Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Hi Alessio,
> I would like to make some questions related to Annalisa's installation
> question. I installed geonode-project only to customize the look.
> Now:
> Thank you very much for your time in advance
> Kind regards
> Julierme
> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
> annalisa.schiavon at gmail.com> wrote:
>> Thanks for the tip!
>> Annalisa
>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> Yes, absolutely. Currently, the deb installation is the most buggy and
>>> unstable one.
>>> It is worth notice that now GeoNode provides natively a way to customize
>>> the interface, at least some part of it, without the need of changing the
>>> files or the templates.
>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>> annalisa.schiavon at gmail.com> ha scritto:
>>>> Ok, thank you so much.
>>>> So you advise against the deb package installation, also if I don't
>>>> think to develop on geonode, only to customize the look?
>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>> If you want to install geonode for development, I would suggest
>>>>> following the procedure here
>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>> If you want to start customizing your own portal (but still develop
>>>>> it), I would suggest starting from a geonode-project template. In that
>>>>> case, follow the instructions here
>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project
>>>>> Otherwise, you can virtual machines either using vagrant or docker.
>>>>> There are several ways and configurations around that you might want to
>>>>> evaluate.
>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>> Please someone may confirm that installation by deb packages, with
>>>>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>> What advantages does have VM Setup with VirtualBox installation (
>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>> And than the installation step by step described in
>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>>>>>> instructions only for a Python virtual environment.
>>>>>> Thank you for any hint.
>>>>>> Annalisa
>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>> Hi all.
>>>>>>> What is the best way to install geonode on Ubuntu for production,
>>>>>>> currently?
>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>> apt-get, following these commands:
>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>> sudo apt-get update
>>>>>>> sudo apt-get install geonode
>>>>>>> Then I had installed geonode-project for a few changes in logos,
>>>>>>> colors and so on:
>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>> -epy,rst
>>>>>>> sudo pip install -e geoportale20
>>>>>>> There are some procedures to migrate data from 2.4 to 2.8 (jumping
>>>>>>> the 2.6 release)?
>>>>>>> Thank you,
>>>>>>> Annalisa
>>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/2f310934/attachment-0001.html>
More information about the geonode-users
