[GeoNode-users] Best way to install geonode
Paulo Frias pfrias82 at gmail.com
Thu Oct 25 07:58:28 PDT 2018
Hi Alessio,
I'm trying to install Geonode on Mac os X, following the tutorial you
recommended (
https://github.com/GeoNode/geonode-project#create-a-custom-project).
When I run the command
pip install -r requirements.txt --upgrade
Nothing happens (I let it run on terminal for more than 2 hours).
Can you help me with some possible solution?
Thanks,
Paulo Frias
On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Julierme,
> please see my responses below.
> "1 - can I make geonode-project my production environment? I meant run
> GeoNode-Project as my production instance on the web."
> Sure, but you will need to tweak a bit security options and settings in
> order to secure and optimize your instance. Especially important are the
> admin passwords and openid keys. This is valid in any case though.
> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
> geonode-project makes use of geonode-core as a dependency. Until we do
> final releases (2.10 and 2.8), meaning that packages will go on Pypi
> repositories, yes, you'll need the geonode-core among the python deps.
> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
> geonode-project runs independently, but it still needs geonode as a
> dependency. However by using it, you won't touch the geonode-core. This
> will allow you to easily keep it up to date with the development version,
> without clashes.
> "4 - If I am not misunderstanding, the tutorial in here <
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode in a
> Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
> GeoNode version or upgrade it to GeoNode 2.9.x?"
> The tutorial and the documentation in general is outdated. We are lacking
> of resources and, unfortunately, we did not found time yet to cleanup it.
> I'm very sorry about that.
> We will try to do it when we start officially the release process.
> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi Alessio,
>> I would like to make some questions related to Annalisa's installation
>> question. I installed geonode-project only to customize the look.
>> Now:
>> a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>> Thank you very much for your time in advance
>> Kind regards
>> Julierme
>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>> annalisa.schiavon at gmail.com> wrote:
>>> Thanks for the tip!
>>> Annalisa
>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>> Yes, absolutely. Currently, the deb installation is the most buggy and
>>>> unstable one.
>>>> It is worth notice that now GeoNode provides natively a way to
>>>> customize the interface, at least some part of it, without the need of
>>>> changing the files or the templates.
>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>> Ok, thank you so much.
>>>>> So you advise against the deb package installation, also if I don't
>>>>> think to develop on geonode,  only to customize the look?
>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>> If you want to install geonode for development, I would suggest
>>>>>> following the procedure here
>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>> If you want to start customizing your own portal (but still develop
>>>>>> it), I would suggest starting from a geonode-project template. In that
>>>>>> case, follow the instructions here
>>>>>> Otherwise, you can virtual machines either using vagrant or docker.
>>>>>> There are several ways and configurations around that you might want to
>>>>>> evaluate.
>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>> Please someone may confirm that installation by deb packages, with
>>>>>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>> What advantages does have VM Setup with VirtualBox installation (
>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>> And than the installation step by step described in
>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>>>>>>> instructions only for a Python virtual environment.
>>>>>>> Thank you for any hint.
>>>>>>> Annalisa
>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>> Hi all.
>>>>>>>> What is the best way to install geonode on Ubuntu for production,
>>>>>>>> currently?
>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>> apt-get, following these commands:
>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>> sudo apt-get update
>>>>>>>> sudo apt-get install geonode
>>>>>>>> Then I had installed geonode-project for a few changes in logos,
>>>>>>>> colors and so on:
>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>  -epy,rst
>>>>>>>> sudo pip install -e geoportale20
>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8 (jumping
>>>>>>>> the 2.6 release)?
>>>>>>>> Thank you,
>>>>>>>> Annalisa
>>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax:     +39 0584 1660272
>>>>>> mob:   +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/d79bea22/attachment-0001.html>
More information about the geonode-users mailing list
