[GeoNode-users] Best way to install geonode
Paulo Frias
pfrias82 at gmail.com
Thu Oct 25 08:32:17 PDT 2018
Sorry for my last email.
pip install -r requirements.txt --upgrade it's working.
On Thu, 25 Oct 2018 at 15:58, Paulo Frias <pfrias82 at gmail.com> wrote:
> Hi Alessio,
> I'm trying to install Geonode on Mac os X, following the tutorial you
> recommended (
> https://github.com/GeoNode/geonode-project#create-a-custom-project).
> When I run the command
> Nothing happens (I let it run on terminal for more than 2 hours).
> Can you help me with some possible solution?
> Thanks,
> Paulo Frias
> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Julierme,
>> please see my responses below.
>> "1 - can I make geonode-project my production environment? I meant run
>> GeoNode-Project as my production instance on the web."
>> Sure, but you will need to tweak a bit security options and settings in
>> order to secure and optimize your instance. Especially important are the
>> admin passwords and openid keys. This is valid in any case though.
>> "2 - do I need GeoNode Core to run together with GeoNode-Project?"
>> geonode-project makes use of geonode-core as a dependency. Until we do
>> final releases (2.10 and 2.8), meaning that packages will go on Pypi
>> repositories, yes, you'll need the geonode-core among the python deps.
>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>> geonode-project runs independently, but it still needs geonode as a
>> dependency. However by using it, you won't touch the geonode-core. This
>> will allow you to easily keep it up to date with the development version,
>> without clashes.
>> "4 - If I am not misunderstanding, the tutorial in here <
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode in
>> a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>> The tutorial and the documentation in general is outdated. We are lacking
>> of resources and, unfortunately, we did not found time yet to cleanup it.
>> I'm very sorry about that.
>> We will try to do it when we start officially the release process.
>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>> Hi Alessio,
>>> I would like to make some questions related to Annalisa's installation
>>> question. I installed geonode-project only to customize the look.
>>> Now:
>>> Thank you very much for your time in advance
>>> Kind regards
>>> Julierme
>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>> annalisa.schiavon at gmail.com> wrote:
>>>> Thanks for the tip!
>>>> Annalisa
>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>> Yes, absolutely. Currently, the deb installation is the most buggy and
>>>>> unstable one.
>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>> customize the interface, at least some part of it, without the need of
>>>>> changing the files or the templates.
>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>> Ok, thank you so much.
>>>>>> So you advise against the deb package installation, also if I don't
>>>>>> think to develop on geonode, only to customize the look?
>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>> following the procedure here
>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>> If you want to start customizing your own portal (but still develop
>>>>>>> it), I would suggest starting from a geonode-project template. In that
>>>>>>> case, follow the instructions here
>>>>>>> Otherwise, you can virtual machines either using vagrant or docker.
>>>>>>> There are several ways and configurations around that you might want to
>>>>>>> evaluate.
>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>> Please someone may confirm that installation by deb packages, with
>>>>>>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>> What advantages does have VM Setup with VirtualBox installation (
>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>> And than the installation step by step described in
>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>> Thank you for any hint.
>>>>>>>> Annalisa
>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>> Hi all.
>>>>>>>>> What is the best way to install geonode on Ubuntu for production,
>>>>>>>>> currently?
>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>>> apt-get, following these commands:
>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>> sudo apt-get update
>>>>>>>>> sudo apt-get install geonode
>>>>>>>>> Then I had installed geonode-project for a few changes in logos,
>>>>>>>>> colors and so on:
>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>> -epy,rst
>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8 (jumping
>>>>>>>>> the 2.6 release)?
>>>>>>>>> Thank you,
>>>>>>>>> Annalisa
>>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax: +39 0584 1660272
>>>>>>> mob: +39 331 6233686
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> notify us immediately by telephone or e-mail.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181025/0e6b44b9/attachment-0001.html>
More information about the geonode-users
