[GeoNode-users] Info about updatelayers command?
Ana Boljevic
ana.boljevic at cedis.me
Fri Oct 26 00:46:20 PDT 2018
Dear Francesco,
We did the following 15 days ago:
git clone https://github.com/GeoNode/geonode.git
cd /home/geonode/geonode
docker-compose up -d
In meantime, we make changes on containers and then commit those changes.
Can you please explain in details how to apply fix from github ?
Regards
Ana
-------- Original message --------
Date: 10/26/18 08:50 (GMT+01:00)
To: Ana Boljevic <ana.boljevic at cedis.me>
Cc: Michael Fedak <mikefedak at gmail.com>, geonode-users <geonode-users at lists.osgeo.org>, geonode-users-bounces at lists.osgeo.org
Subject: Re: [GeoNode-users] Info about updatelayers command?
Hi Ana,
can you please explain what did you do? The better to try is to pull the latest code from github and then run "docker-compose up --build" regardless of the version. The fix is for sure also in master.
Hope this helps,
Francesco
Il giorno ven 26 ott 2018 alle ore 07:16 Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> ha scritto:
Dears,
We have tried to implement solution by Mr. Fabiani:
https://github.com/GeoNode/geonode/pull/3986/files
but after we have manually changed those 4 files django4geonode containers can't bring up anymore.
Does this solution apply also for GeoNode version 2.10rc4 ?
Thanks in advance.
Regards,
Ana Boljević
Direkcija za razvoj, pristup mreži i ICT
Sektor za ICT
Služba za GIS i tehničku bazu podataka
[CEDIS]
DOO „Crnogorski elektrodistributivni sistem“ Podgorica
Ivana Milutinovića br.12, Podgorica
Tel: +382 20 408 473
www.cedis.me<http://www.cedis.me/>
[jelkica]Please do not print this e-mail unless you really need to
From: Michael Fedak [mailto:mikefedak at gmail.com<mailto:mikefedak at gmail.com>]
Sent: Monday, October 22, 2018 3:20 PM
To: Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>>
Cc: geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>; geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
I had a similar issue on 2.8 last week. See here for the discussion/fix: https://github.com/GeoNode/geonode/issues/3984
On Mon, Oct 22, 2018 at 7:25 AM Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Dear Geonode community,
If someone knows little bit more about this, we would appreciate your help :) Explanation below:
We have installed Geonode on docker (version 2.10rc4). We imported first kml layer but updatelayers (from inside of django4geonode container) report problem "Could not ADD GeoServer User None Rule for Layer":
root at 5058e8a1637f:/usr/src/app# ./manage.py updatelayers
Inspecting the available layers in GeoServer ...
Found 1 layers, starting processing
Stopping process because --ignore-errors was not set and an error was found.
File "./manage.py", line 29, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 364, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 356, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 283, in run_from_argv
self.execute(*args, **cmd_options)
File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 330, in execute
output = self.handle(*args, **options)
File "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line 124, in handle
execute_signals=True)
File "/usr/src/app/geonode/geoserver/helpers.py", line 637, in gs_slurp
layer.set_permissions(perm_spec)
File "/usr/src/app/geonode/security/models.py", line 216, in set_permissions
sync_geofence_with_guardian(self.layer, perms, group=group)
File "/usr/src/app/geonode/decorators.py", line 44, in wrapper
return func(*args, **kwargs)
File "/usr/src/app/geonode/security/utils.py", line 392, in sync_geofence_with_guardian
_update_geofence_rule(layer.name<http://layer.name>, layer.workspace, service)
File "/usr/src/app/geonode/security/utils.py", line 563, in _update_geofence_rule
raise RuntimeError(msg)
Exception: ('Failed to process novi_r6_Slijepac_most_10kV', RuntimeError("Could not ADD GeoServer User None Rule for Layer u'novi_r6_Slijepac_most_10kV'",))
But the same command from celery4geonode container has different output:
root at bca672a5673d:/usr/src/app# ./manage.py updatelayers
Found 6 layers, starting processing
/usr/local/lib/python2.7/site-packages/owslib/iso.py:117: FutureWarning: the .identification and .serviceidentification properties will merge into .identification being a list of properties. This is currently implemented in .identificationinfo. Please see https://github.com/geopython/OWSLib/issues/38 for more information
FutureWarning)
/usr/local/lib/python2.7/site-packages/owslib/iso.py:482: FutureWarning: The .keywords and .keywords2 properties will merge into the .keywords property in the future, with .keywords becoming a list of MD_Keywords instances. This is currently implemented in .keywords2. Please see https://github.com/geopython/OWSLib/issues/301 for more information
FutureWarning)
/usr/local/lib/python2.7/site-packages/geoserver/style.py:73: FutureWarning: The behavior of this method will change in future versions. Use specific 'len(elem)' or 'elem is not None' test instead.
if not user_style:
/usr/local/lib/python2.7/site-packages/geoserver/style.py:77: FutureWarning: The behavior of this method will change in future versions. Use specific 'len(elem)' or 'elem is not None' test instead.
if user_style:
... Creating Thumbnail for Layer [geonode:OPSTINE]
[updated] Layer OPSTINE (1/6)
... Creating Thumbnail for Layer [geonode:novi_novi_r6_Pavino_Polje_10kV_izmijenjen]
[updated] Layer novi_novi_r6_Pavino_Polje_10kV_izmijenjen (2/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Ambarine_Przista_10kV]
[created] Layer novi_r6_Ambarine_Przista_10kV (3/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Gimnazija_10_kV]
[updated] Layer novi_r6_Gimnazija_10_kV (4/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Planinica_10_kV]
[updated] Layer novi_r6_Planinica_10_kV (5/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Rasovo_10kV]
[updated] Layer novi_r6_Rasovo_10kV (6/6)
Finished processing 6 layers in 53.0 seconds.
1 Created layers
5 Updated layers
0 Failed layers
8.830000 seconds per layer
Is such behavior normal ?
Thanks in advance.
Kind regards,
Ana Boljević
Sektor za ICT
[CEDIS]
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/13e0d1ef/attachment-0001.html>
More information about the geonode-users
