[GeoNode-users] Info about updatelayers command?
francesco bartoli
xbartolone at gmail.com
Fri Oct 26 02:11:37 PDT 2018
If you apply changes or you have got new updates from the repo then you
have to rebuild the image so please try to add and use the option "--build"
that I mentioned above.
However if you are going to modify geonode and don't want to contribute
back with pull requests then the suggested method would be to use a
geonode-project.
Il giorno ven 26 ott 2018 alle ore 09:46 Ana Boljevic <ana.boljevic at cedis.me>
ha scritto:
> Dear Francesco,
> We did the following 15 days ago:
> git clone https://github.com/GeoNode/geonode.git
> cd /home/geonode/geonode
> docker-compose up -d
> In meantime, we make changes on containers and then commit those changes.
> Can you please explain in details how to apply fix from github ?
> Regards
> Ana
> -------- Original message --------
> From: francesco bartoli <xbartolone at gmail.com>
> Date: 10/26/18 08:50 (GMT+01:00)
> To: Ana Boljevic <ana.boljevic at cedis.me>
> Cc: Michael Fedak <mikefedak at gmail.com>, geonode-users <
> geonode-users at lists.osgeo.org>, geonode-users-bounces at lists.osgeo.org
> Subject: Re: [GeoNode-users] Info about updatelayers command?
> Hi Ana,
> can you please explain what did you do? The better to try is to pull the
> latest code from github and then run "docker-compose up --build" regardless
> of the version. The fix is for sure also in master.
> Hope this helps,
> Francesco
> Il giorno ven 26 ott 2018 alle ore 07:16 Ana Boljevic <
> ana.boljevic at cedis.me> ha scritto:
>> Dears,
>> We have tried to implement solution by Mr. Fabiani:
>> https://github.com/GeoNode/geonode/pull/3986/files
>> but after we have manually changed those 4 files django4geonode
>> containers can't bring up anymore.
>> Does this solution apply also for GeoNode version 2.10rc4 ?
>> Thanks in advance.
>> Regards,
>> *Ana Boljević*
>> Direkcija za razvoj, pristup mreži i ICT
>> Sektor za ICT
>> Služba za GIS i tehničku bazu podataka
>> *[image: CEDIS]*
>> *DOO „Crnogorski elektrodistributivni sistem“ Podgorica*
>> Ivana Milutinovića br.12, Podgorica
>> Tel: +382 20 408 473
>> *www.cedis.me <http://www.cedis.me/>*
>> [image: jelkica]Please do not print this e-mail unless you really need to
>> *From:* Michael Fedak [mailto:mikefedak at gmail.com]
>> *Sent:* Monday, October 22, 2018 3:20 PM
>> *To:* Ana Boljevic <ana.boljevic at cedis.me>
>> *Cc:* geonode-users-bounces at lists.osgeo.org; geonode-users <
>> *Subject:* Re: [GeoNode-users] Info about updatelayers command?
>> I had a similar issue on 2.8 last week. See here for the
>> discussion/fix: https://github.com/GeoNode/geonode/issues/3984
>> On Mon, Oct 22, 2018 at 7:25 AM Ana Boljevic <ana.boljevic at cedis.me>
>> wrote:
>> Dear Geonode community,
>> If someone knows little bit more about this, we would appreciate your
>> help J Explanation below:
>> We have installed Geonode on docker (version 2.10rc4). We imported first
>> kml layer but updatelayers (from inside of django4geonode container) report
>> problem "Could not ADD GeoServer User None Rule for Layer":
>> root at 5058e8a1637f:/usr/src/app# ./manage.py updatelayers
>> Inspecting the available layers in GeoServer ...
>> Found 1 layers, starting processing
>> Stopping process because --ignore-errors was not set and an error was
>> found.
>> Traceback (most recent call last):
>> File "./manage.py", line 29, in <module>
>> execute_from_command_line(sys.argv)
>> File
>> "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 364, in execute_from_command_line
>> utility.execute()
>> File
>> line 356, in execute
>> self.fetch_command(subcommand).run_from_argv(self.argv)
>> File
>> "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
>> line 283, in run_from_argv
>> self.execute(*args, **cmd_options)
>> File
>> line 330, in execute
>> output = self.handle(*args, **options)
>> File
>> "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line
>> 124, in handle
>> execute_signals=True)
>> File "/usr/src/app/geonode/geoserver/helpers.py", line 637, in gs_slurp
>> layer.set_permissions(perm_spec)
>> File "/usr/src/app/geonode/security/models.py", line 216, in
>> set_permissions
>> sync_geofence_with_guardian(self.layer, perms, group=group)
>> File "/usr/src/app/geonode/decorators.py", line 44, in wrapper
>> return func(*args, **kwargs)
>> File "/usr/src/app/geonode/security/utils.py", line 392, in
>> _update_geofence_rule(layer.name, layer.workspace, service)
>> File "/usr/src/app/geonode/security/utils.py", line 563, in
>> raise RuntimeError(msg)
>> Exception: ('Failed to process novi_r6_Slijepac_most_10kV',
>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>> u'novi_r6_Slijepac_most_10kV'",))
>> But the same command from celery4geonode container has different output:
>> root at bca672a5673d:/usr/src/app# ./manage.py updatelayers
>> Found 6 layers, starting processing
>> /usr/local/lib/python2.7/site-packages/owslib/iso.py:117: FutureWarning:
>> the .identification and .serviceidentification properties will merge into
>> .identification being a list of properties. This is currently implemented
>> in .identificationinfo. Please see
>> https://github.com/geopython/OWSLib/issues/38 for more information
>> FutureWarning)
>> /usr/local/lib/python2.7/site-packages/owslib/iso.py:482: FutureWarning:
>> The .keywords and .keywords2 properties will merge into the .keywords
>> property in the future, with .keywords becoming a list of MD_Keywords
>> instances. This is currently implemented in .keywords2. Please see
>> https://github.com/geopython/OWSLib/issues/301 for more information
>> FutureWarning)
>> /usr/local/lib/python2.7/site-packages/geoserver/style.py:73:
>> FutureWarning: The behavior of this method will change in future versions.
>> Use specific 'len(elem)' or 'elem is not None' test instead.
>> if not user_style:
>> /usr/local/lib/python2.7/site-packages/geoserver/style.py:77:
>> if user_style:
>> ... Creating Thumbnail for Layer [geonode:OPSTINE]
>> [updated] Layer OPSTINE (1/6)
>> [geonode:novi_novi_r6_Pavino_Polje_10kV_izmijenjen]
>> [updated] Layer novi_novi_r6_Pavino_Polje_10kV_izmijenjen (2/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Ambarine_Przista_10kV]
>> [created] Layer novi_r6_Ambarine_Przista_10kV (3/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Gimnazija_10_kV]
>> [updated] Layer novi_r6_Gimnazija_10_kV (4/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Planinica_10_kV]
>> [updated] Layer novi_r6_Planinica_10_kV (5/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Rasovo_10kV]
>> [updated] Layer novi_r6_Rasovo_10kV (6/6)
>> Finished processing 6 layers in 53.0 seconds.
>> 1 Created layers
>> 5 Updated layers
>> 0 Failed layers
>> 8.830000 seconds per layer
>> *Is such behavior normal ?*
>> Thanks in advance.
>> Kind regards,
>> *Ana Boljević*
>> Sektor za ICT
>> *[image: CEDIS]*
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/8cd3aea6/attachment-0001.html>
More information about the geonode-users
