[GeoNode-users] Geonode 2.8 Installation
aditya fikri ghozali adityafikrighozali at gmail.com
Fri Oct 26 01:36:39 PDT 2018
OK, Thank you Toni.
Best Regards,
*Aditya Fikri Ghozali*
Bachelor of Geodesy and Geomatics Engineering
Bandung Institute of Technology
Mobile: +6281222888814
e-mail: adityafikrighozali at gmail.com
 | www.adityafikrighozali.com <http://www.adityafikrighozali.com>
        <https://www.facebook.com/welcomemybest>
<https://www.linkedin.com/in/fikriaditya/>
<https://www.youtube.com/user/adityafikri/>
<https://medium.com/@adityafikrighozali>
On Fri, Oct 26, 2018 at 2:54 PM <geonode-users-request at lists.osgeo.org>
wrote:
> Send geonode-users mailing list submissions to
>         geonode-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/geonode-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         geonode-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-users digest..."
> Today's Topics:
>    1. Re: Geonode 2.8 Installation (Toni Schönbuchner)
>    2. Re: Best way to install geonode (Alessio Fabiani)
> Message: 1
> Date: Fri, 26 Oct 2018 09:48:53 +0200
> From: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> To: geonode-users <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] Geonode 2.8 Installation
> Message-ID: <38AFE69B-3C40-47E2-8870-1E1273D30194 at csgis.de>
> Content-Type: text/plain; charset="utf-8"
> Hi Aditya,
> Before paver setup you would have to change the path here:
> https://github.com/GeoNode/geonode/blob/master/dev_config.yml <
> https://github.com/GeoNode/geonode/blob/master/dev_config.yml>
> Cheers,
> Toni
> > Message: 1
> > Date: Fri, 26 Oct 2018 14:02:05 +0700
> > From: aditya fikri ghozali <adityafikrighozali at gmail.com>
> > To: geonode-users at lists.osgeo.org
> > Subject: [GeoNode-users] Geonode 2.8 Installation
> > Message-ID:
> CABSG5bbZEz5CfagPWVGitPbaaYdhpYqyfxpdwihjFkNGEaaTmg at mail.gmail.com>
> > i am having problem installing Geonode installation on ubuntu 16.04. I am
> > following the installation step here
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> > the installation stop at *paver setup , *it says cannot access
> > build.geonode.org
> > later i found that build.geonode.org  is down, and the alternative was
> > https://build.geo-solutions.it/geonode/geoserver/latest/ .
> > "how do i change the installation source to the alternative link and
> > continue installation?" Or is there any updated installation step?
> > Best Regards,
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <
> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/fa4d85db/attachment-0001.html
> URL: <
> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/2f315b32/attachment-0001.html
> Message: 2
> Date: Fri, 26 Oct 2018 09:53:45 +0200
> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> To: Paulo Frias <pfrias82 at gmail.com>
> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it>,  Julierme
>         Pinheiro <juliermeopensourcedeveloper at gmail.com>,  geonode-users
> Subject: Re: [GeoNode-users] Best way to install geonode
> Message-ID:
>         <CAM7ZvL+p50A=
> n_zOshB3PQKN9brju0FKofV9YPB09DwC7Rt_KQ at mail.gmail.com>
> Hi Paulo,
> can you describe what's happening with a bit more detail?
> That command should just start downloading the Python dependencies. If it
> is stuck, most probably there's a problem reaching the PyPi repositories.
> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <pfrias82 at gmail.com>
> ha scritto:
> > Hi Alessio,
> > I'm trying to install Geonode on Mac os X, following the tutorial you
> > recommended (
> > https://github.com/GeoNode/geonode-project#create-a-custom-project).
> > When I run the command
> > pip install -r requirements.txt --upgrade
> > Nothing happens (I let it run on terminal for more than 2 hours).
> > Can you help me with some possible solution?
> > Thanks,
> > Paulo Frias
> > On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
> > alessio.fabiani at geo-solutions.it> wrote:
> >> Hi Julierme,
> >> please see my responses below.
> >> "1 - can I make geonode-project my production environment? I meant run
> >> GeoNode-Project as my production instance on the web."
> >> Sure, but you will need to tweak a bit security options and settings in
> >> order to secure and optimize your instance. Especially important are the
> >> admin passwords and openid keys. This is valid in any case though.
> >> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
> >> geonode-project makes use of geonode-core as a dependency. Until we do
> >> final releases (2.10 and 2.8), meaning that packages will go on Pypi
> >> repositories, yes, you'll need the geonode-core among the python deps.
> >> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
> >> geonode-project runs independently, but it still needs geonode as a
> >> dependency. However by using it, you won't touch the geonode-core. This
> >> will allow you to easily keep it up to date with the development
> version,
> >> without clashes.
> >> "4 - If I am not misunderstanding, the tutorial in here <
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html
> >> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode in
> >> a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
> >> GeoNode version or upgrade it to GeoNode 2.9.x?"
> >> The tutorial and the documentation in general is outdated. We are
> lacking
> >> of resources and, unfortunately, we did not found time yet to cleanup
> it.
> >> I'm very sorry about that.
> >> We will try to do it when we start officially the release process.
> >> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
> >> juliermeopensourcedeveloper at gmail.com> ha scritto:
> >>> Hi Alessio,
> >>> I would like to make some questions related to Annalisa's installation
> >>> question. I installed geonode-project only to customize the look.
> >>> Now:
> in
> >>> Thank you very much for your time in advance
> >>> Kind regards
> >>> Julierme
> >>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
> >>> annalisa.schiavon at gmail.com> wrote:
> >>>> Thanks for the tip!
> >>>> Annalisa
> >>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
> >>>> alessio.fabiani at geo-solutions.it> ha scritto:
> >>>>> Yes, absolutely. Currently, the deb installation is the most buggy
> and
> >>>>> unstable one.
> >>>>> It is worth notice that now GeoNode provides natively a way to
> >>>>> customize the interface, at least some part of it, without the need
> of
> >>>>> changing the files or the templates.
> >>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
> >>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
> >>>>> annalisa.schiavon at gmail.com> ha scritto:
> >>>>>> Ok, thank you so much.
> >>>>>> So you advise against the deb package installation, also if I don't
> >>>>>> think to develop on geonode,  only to customize the look?
> >>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
> >>>>>>> If you want to install geonode for development, I would suggest
> >>>>>>> following the procedure here
> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
> >>>>>>> If you want to start customizing your own portal (but still develop
> >>>>>>> it), I would suggest starting from a geonode-project template. In
> that
> >>>>>>> case, follow the instructions here
> >>>>>>> Otherwise, you can virtual machines either using vagrant or docker.
> >>>>>>> There are several ways and configurations around that you might
> want to
> >>>>>>> evaluate.
> >>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
> >>>>>>>> Please someone may confirm that installation by deb packages, with
> >>>>>>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
> >>>>>>>> What advantages does have VM Setup with VirtualBox installation (
> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html
> >>>>>>>> And than the installation step by step described in
> >>>>>>>> If I want to changes logos, colors and texts, is it recommended
> >>>>>>>> install geonode-project and create a template, in similar way
> than once?
> >>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
> >>>>>>>> instructions only for a Python virtual environment.
> >>>>>>>> Thank you for any hint.
> >>>>>>>> Annalisa
> >>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
> >>>>>>>>> Hi all.
> >>>>>>>>> What is the best way to install geonode on Ubuntu for production,
> >>>>>>>>> currently?
> >>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
> >>>>>>>>> apt-get, following these commands:
> >>>>>>>>> sudo add-apt-repository ppa:geonode/stable
> >>>>>>>>> sudo apt-get update
> >>>>>>>>> sudo apt-get install geonode
> >>>>>>>>> Then I had installed geonode-project for a few changes in logos,
> >>>>>>>>> colors and so on:
> >>>>>>>>> django-admin startproject geoportale20 --template=
> >>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
> >>>>>>>>>  -epy,rst
> >>>>>>>>> sudo pip install -e geoportale20
> >>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
> (jumping
> >>>>>>>>> the 2.6 release)?
> >>>>>>>>> Thank you,
> >>>>>>>>> Annalisa
> >>>>>>>>> _______________________________________________
> >>>>>>> GeoServer Professional Services from the experts! Visit
> >>>>>>> http://goo.gl/it488V for more information.
> >>>>>>> Ing. Alessio Fabiani
> >>>>>>> @alfa7691
> >>>>>>> Founder/Technical Lead
> >>>>>>> GeoSolutions S.A.S.
> >>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> >>>>>>> phone: +39 0584 962313
> >>>>>>> fax:     +39 0584 1660272
> >>>>>>> mob:   +39 331 6233686
> >>>>>>> http://www.geo-solutions.it
> >>>>>>> http://twitter.com/geosolutions_it
> >>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
> >>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
> “GDPR”),
> >>>>>>> si precisa che ogni circostanza inerente alla presente email (il
> suo
> >>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui
> conoscenza è
> >>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se
> il
> >>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
> altra
> >>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene
> notizia.
> >>>>>>> This email is intended only for the person or entity to which it is
> >>>>>>> addressed and may contain information that is privileged,
> confidential or
> >>>>>>> otherwise protected from disclosure. We remind that - as provided
> by
> >>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or
> use of this
> >>>>>>> e-mail or the information herein by anyone other than the intended
> >>>>>>> recipient is prohibited. If you have received this email by
> mistake, please
> >>>>>>> notify us immediately by telephone or e-mail.
> >>>>> @alfa7691
> >>>>> GeoSolutions S.A.S.
> “GDPR”),
> >>>>> si precisa che ogni circostanza inerente alla presente email (il suo
> >>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza
> è
> >>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> altra
> notizia.
> confidential or
> >>>>> otherwise protected from disclosure. We remind that - as provided by
> >>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use
> of this
> >>>>> recipient is prohibited. If you have received this email by mistake,
> please
> >> @alfa7691
> >> GeoSolutions S.A.S.
> >> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> >> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> >> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> >> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> notizia.
> >> addressed and may contain information that is privileged, confidential
> or
> >> European Regulation 2016/679 “GDPR” - copying, dissemination or use of
> this
> please
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> addressed and may contain information that is privileged, confidential or
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> recipient is prohibited. If you have received this email by mistake, please
> URL: <
> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/46552fe1/attachment.html
> Subject: Digest Footer
> End of geonode-users Digest, Vol 45, Issue 96
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/c0c7d185/attachment-0001.html>
More information about the geonode-users mailing list
