[GeoNode-users] Geonode 2.8 Installation
francesco bartoli
xbartolone at gmail.com
Fri Oct 26 02:14:29 PDT 2018
Hi can you try to pull the latest code which is supposed to have that
change yet?
Il giorno ven 26 ott 2018 alle ore 10:37 aditya fikri ghozali <
adityafikrighozali at gmail.com> ha scritto:
> OK, Thank you Toni.
> Best Regards,
> *Aditya Fikri Ghozali*
> Bachelor of Geodesy and Geomatics Engineering
> Bandung Institute of Technology
> Mobile: +6281222888814
> e-mail: adityafikrighozali at gmail.com
> | www.adityafikrighozali.com <http://www.adityafikrighozali.com>
> <https://www.facebook.com/welcomemybest>
> <https://www.linkedin.com/in/fikriaditya/>
> <https://www.youtube.com/user/adityafikri/>
> <https://medium.com/@adityafikrighozali>
> On Fri, Oct 26, 2018 at 2:54 PM <geonode-users-request at lists.osgeo.org>
> wrote:
>> Send geonode-users mailing list submissions to
>> geonode-users at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> geonode-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of geonode-users digest..."
>> Today's Topics:
>> 1. Re: Geonode 2.8 Installation (Toni Schönbuchner)
>> 2. Re: Best way to install geonode (Alessio Fabiani)
>> Message: 1
>> Date: Fri, 26 Oct 2018 09:48:53 +0200
>> From: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>> To: geonode-users <geonode-users at lists.osgeo.org>
>> Subject: Re: [GeoNode-users] Geonode 2.8 Installation
>> Message-ID: <38AFE69B-3C40-47E2-8870-1E1273D30194 at csgis.de>
>> Content-Type: text/plain; charset="utf-8"
>> Hi Aditya,
>> Before paver setup you would have to change the path here:
>> https://github.com/GeoNode/geonode/blob/master/dev_config.yml <
>> https://github.com/GeoNode/geonode/blob/master/dev_config.yml>
>> Cheers,
>> Toni
>> > Message: 1
>> > Date: Fri, 26 Oct 2018 14:02:05 +0700
>> > From: aditya fikri ghozali <adityafikrighozali at gmail.com>
>> > To: geonode-users at lists.osgeo.org
>> > Subject: [GeoNode-users] Geonode 2.8 Installation
>> > Message-ID:
>> CABSG5bbZEz5CfagPWVGitPbaaYdhpYqyfxpdwihjFkNGEaaTmg at mail.gmail.com>
>> > i am having problem installing Geonode installation on ubuntu 16.04. I
>> am
>> > following the installation step here
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>> > the installation stop at *paver setup , *it says cannot access
>> > build.geonode.org
>> > later i found that build.geonode.org is down, and the alternative was
>> > https://build.geo-solutions.it/geonode/geoserver/latest/ .
>> > "how do i change the installation source to the alternative link and
>> > continue installation?" Or is there any updated installation step?
>> > Best Regards,
>> > -------------- next part --------------
>> > An HTML attachment was scrubbed...
>> > URL: <
>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/fa4d85db/attachment-0001.html
>> URL: <
>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/2f315b32/attachment-0001.html
>> Message: 2
>> Date: Fri, 26 Oct 2018 09:53:45 +0200
>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>> To: Paulo Frias <pfrias82 at gmail.com>
>> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it>, Julierme
>> Pinheiro <juliermeopensourcedeveloper at gmail.com>, geonode-users
>> Subject: Re: [GeoNode-users] Best way to install geonode
>> Message-ID:
>> <CAM7ZvL+p50A=
>> n_zOshB3PQKN9brju0FKofV9YPB09DwC7Rt_KQ at mail.gmail.com>
>> Hi Paulo,
>> can you describe what's happening with a bit more detail?
>> That command should just start downloading the Python dependencies. If it
>> is stuck, most probably there's a problem reaching the PyPi repositories.
>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <pfrias82 at gmail.com>
>> ha scritto:
>> > Hi Alessio,
>> > I'm trying to install Geonode on Mac os X, following the tutorial you
>> > recommended (
>> > https://github.com/GeoNode/geonode-project#create-a-custom-project).
>> > When I run the command
>> > pip install -r requirements.txt --upgrade
>> > Nothing happens (I let it run on terminal for more than 2 hours).
>> > Can you help me with some possible solution?
>> > Thanks,
>> > Paulo Frias
>> > On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>> > alessio.fabiani at geo-solutions.it> wrote:
>> >> Hi Julierme,
>> >> please see my responses below.
>> >> "1 - can I make geonode-project my production environment? I meant run
>> >> GeoNode-Project as my production instance on the web."
>> >> Sure, but you will need to tweak a bit security options and settings in
>> >> order to secure and optimize your instance. Especially important are
>> the
>> >> admin passwords and openid keys. This is valid in any case though.
>> >> "2 - do I need GeoNode Core to run together with GeoNode-Project?"
>> >> geonode-project makes use of geonode-core as a dependency. Until we do
>> >> final releases (2.10 and 2.8), meaning that packages will go on Pypi
>> >> repositories, yes, you'll need the geonode-core among the python deps.
>> >> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>> >> geonode-project runs independently, but it still needs geonode as a
>> >> dependency. However by using it, you won't touch the geonode-core. This
>> >> will allow you to easily keep it up to date with the development
>> version,
>> >> without clashes.
>> >> "4 - If I am not misunderstanding, the tutorial in here <
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html
>> >> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>> in
>> >> a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>> >> GeoNode version or upgrade it to GeoNode 2.9.x?"
>> >> The tutorial and the documentation in general is outdated. We are
>> lacking
>> >> of resources and, unfortunately, we did not found time yet to cleanup
>> it.
>> >> I'm very sorry about that.
>> >> We will try to do it when we start officially the release process.
>> >> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>> >> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> >>> Hi Alessio,
>> >>> I would like to make some questions related to Annalisa's installation
>> >>> question. I installed geonode-project only to customize the look.
>> >>> Now:
>> in
>> same
>> >>> Thank you very much for your time in advance
>> >>> Kind regards
>> >>> Julierme
>> >>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>> >>> annalisa.schiavon at gmail.com> wrote:
>> >>>> Thanks for the tip!
>> >>>> Annalisa
>> >>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>> >>>> alessio.fabiani at geo-solutions.it> ha scritto:
>> >>>>> Yes, absolutely. Currently, the deb installation is the most buggy
>> and
>> >>>>> unstable one.
>> >>>>> It is worth notice that now GeoNode provides natively a way to
>> >>>>> customize the interface, at least some part of it, without the need
>> of
>> >>>>> changing the files or the templates.
>> >>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>> >>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>> >>>>> annalisa.schiavon at gmail.com> ha scritto:
>> >>>>>> Ok, thank you so much.
>> >>>>>> So you advise against the deb package installation, also if I don't
>> >>>>>> think to develop on geonode, only to customize the look?
>> >>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>> >>>>>>> If you want to install geonode for development, I would suggest
>> >>>>>>> following the procedure here
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>> >>>>>>> If you want to start customizing your own portal (but still
>> develop
>> >>>>>>> it), I would suggest starting from a geonode-project template. In
>> that
>> >>>>>>> case, follow the instructions here
>> >>>>>>> Otherwise, you can virtual machines either using vagrant or
>> docker.
>> >>>>>>> There are several ways and configurations around that you might
>> want to
>> >>>>>>> evaluate.
>> >>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>> >>>>>>>> Please someone may confirm that installation by deb packages,
>> with
>> >>>>>>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at
>> now?)
>> >>>>>>>> What advantages does have VM Setup with VirtualBox installation (
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html
>> >>>>>>>> And than the installation step by step described in
>> >>>>>>>> If I want to changes logos, colors and texts, is it recommended
>> >>>>>>>> install geonode-project and create a template, in similar way
>> than once?
>> >>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>> >>>>>>>> instructions only for a Python virtual environment.
>> >>>>>>>> Thank you for any hint.
>> >>>>>>>> Annalisa
>> >>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>> >>>>>>>>> Hi all.
>> >>>>>>>>> What is the best way to install geonode on Ubuntu for
>> production,
>> >>>>>>>>> currently?
>> >>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>> >>>>>>>>> apt-get, following these commands:
>> >>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>> >>>>>>>>> sudo apt-get update
>> >>>>>>>>> sudo apt-get install geonode
>> >>>>>>>>> Then I had installed geonode-project for a few changes in logos,
>> >>>>>>>>> colors and so on:
>> >>>>>>>>> django-admin startproject geoportale20 --template=
>> >>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>> >>>>>>>>> -epy,rst
>> >>>>>>>>> sudo pip install -e geoportale20
>> >>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>> (jumping
>> >>>>>>>>> the 2.6 release)?
>> >>>>>>>>> Thank you,
>> >>>>>>>>> Annalisa
>> >>>>>>>>> _______________________________________________
>> >>>>>>> GeoServer Professional Services from the experts! Visit
>> >>>>>>> http://goo.gl/it488V for more information.
>> >>>>>>> Ing. Alessio Fabiani
>> >>>>>>> @alfa7691
>> >>>>>>> Founder/Technical Lead
>> >>>>>>> GeoSolutions S.A.S.
>> >>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> >>>>>>> phone: +39 0584 962313
>> >>>>>>> fax: +39 0584 1660272
>> >>>>>>> mob: +39 331 6233686
>> >>>>>>> http://www.geo-solutions.it
>> >>>>>>> http://twitter.com/geosolutions_it
>> >>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>> >>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>> dati “GDPR”),
>> >>>>>>> si precisa che ogni circostanza inerente alla presente email (il
>> suo
>> >>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui
>> conoscenza è
>> >>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se
>> il
>> >>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>> altra
>> >>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene
>> notizia.
>> >>>>>>> This email is intended only for the person or entity to which it
>> is
>> >>>>>>> addressed and may contain information that is privileged,
>> confidential or
>> >>>>>>> otherwise protected from disclosure. We remind that - as provided
>> by
>> >>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or
>> use of this
>> >>>>>>> e-mail or the information herein by anyone other than the intended
>> >>>>>>> recipient is prohibited. If you have received this email by
>> mistake, please
>> >>>>>>> notify us immediately by telephone or e-mail.
>> >>>>> @alfa7691
>> >>>>> GeoSolutions S.A.S.
>> >>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
>> “GDPR”),
>> >>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>> conoscenza è
>> >>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> altra
>> notizia.
>> >>>>> This email is intended only for the person or entity to which it is
>> confidential or
>> >>>>> otherwise protected from disclosure. We remind that - as provided by
>> >>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use
>> of this
>> mistake, please
>> >> @alfa7691
>> >> GeoSolutions S.A.S.
>> >> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> >> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>> si
>> >> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> >> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> notizia.
>> >> addressed and may contain information that is privileged, confidential
>> or
>> >> European Regulation 2016/679 “GDPR” - copying, dissemination or use of
>> this
>> >> recipient is prohibited. If you have received this email by mistake,
>> please
>> @alfa7691
>> GeoSolutions S.A.S.
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
>> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> addressed and may contain information that is privileged, confidential or
>> this
>> please
>> URL: <
>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/46552fe1/attachment.html
>> Subject: Digest Footer
>> End of geonode-users Digest, Vol 45, Issue 96
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/fed09bb1/attachment-0001.html>
More information about the geonode-users
