[GeoNode-users] Best way to install geonode
Paulo Frias
pfrias82 at gmail.com
Fri Oct 26 07:05:14 PDT 2018
Hi Alessio,
The (pip install -r requirements.txt --upgrade) worked fine after another
try.
Now I'm stucked in the command
(DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
This is the error produced:
(Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
<module>
from paver.tasks import main
ImportError: No module named paver.tasks
Any idea how to solve this?
Thanks,
Paulo
On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Paulo,
> can you describe what's happening with a bit more detail?
> That command should just start downloading the Python dependencies. If it
> is stuck, most probably there's a problem reaching the PyPi repositories.
> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <pfrias82 at gmail.com>
> ha scritto:
>> Hi Alessio,
>> I'm trying to install Geonode on Mac os X, following the tutorial you
>> recommended (
>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>> When I run the command
>> Nothing happens (I let it run on terminal for more than 2 hours).
>> Can you help me with some possible solution?
>> Thanks,
>> Paulo Frias
>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>> Hi Julierme,
>>> please see my responses below.
>>> "1 - can I make geonode-project my production environment? I meant run
>>> GeoNode-Project as my production instance on the web."
>>> Sure, but you will need to tweak a bit security options and settings in
>>> order to secure and optimize your instance. Especially important are the
>>> admin passwords and openid keys. This is valid in any case though.
>>> "2 - do I need GeoNode Core to run together with GeoNode-Project?"
>>> geonode-project makes use of geonode-core as a dependency. Until we do
>>> final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>> repositories, yes, you'll need the geonode-core among the python deps.
>>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>>> geonode-project runs independently, but it still needs geonode as a
>>> dependency. However by using it, you won't touch the geonode-core. This
>>> will allow you to easily keep it up to date with the development version,
>>> without clashes.
>>> "4 - If I am not misunderstanding, the tutorial in here <
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode in
>>> a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>>> The tutorial and the documentation in general is outdated. We are
>>> lacking of resources and, unfortunately, we did not found time yet to
>>> cleanup it. I'm very sorry about that.
>>> We will try to do it when we start officially the release process.
>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>> Hi Alessio,
>>>> I would like to make some questions related to Annalisa's installation
>>>> question. I installed geonode-project only to customize the look.
>>>> Now:
>>>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>>>> Thank you very much for your time in advance
>>>> Kind regards
>>>> Julierme
>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>> annalisa.schiavon at gmail.com> wrote:
>>>>> Thanks for the tip!
>>>>> Annalisa
>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>> Yes, absolutely. Currently, the deb installation is the most buggy
>>>>>> and unstable one.
>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>> customize the interface, at least some part of it, without the need of
>>>>>> changing the files or the templates.
>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>>> Ok, thank you so much.
>>>>>>> So you advise against the deb package installation, also if I don't
>>>>>>> think to develop on geonode, only to customize the look?
>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>>> following the procedure here
>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>> If you want to start customizing your own portal (but still develop
>>>>>>>> it), I would suggest starting from a geonode-project template. In that
>>>>>>>> case, follow the instructions here
>>>>>>>> Otherwise, you can virtual machines either using vagrant or docker.
>>>>>>>> There are several ways and configurations around that you might want to
>>>>>>>> evaluate.
>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>> Please someone may confirm that installation by deb packages, with
>>>>>>>>> ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>> What advantages does have VM Setup with VirtualBox installation (
>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>> And than the installation step by step described in
>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>> Thank you for any hint.
>>>>>>>>> Annalisa
>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>> Hi all.
>>>>>>>>>> What is the best way to install geonode on Ubuntu for production,
>>>>>>>>>> currently?
>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>>>> apt-get, following these commands:
>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>> sudo apt-get update
>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>> Then I had installed geonode-project for a few changes in logos,
>>>>>>>>>> colors and so on:
>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>> -epy,rst
>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>> Thank you,
>>>>>>>>>> Annalisa
>>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>> Ing. Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> Founder/Technical Lead
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>> phone: +39 0584 962313
>>>>>>>> fax: +39 0584 1660272
>>>>>>>> mob: +39 331 6233686
>>>>>>>> http://www.geo-solutions.it
>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/71b1d585/attachment-0001.html>
More information about the geonode-users
