[GeoNode-users] Best way to install geonode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Oct 26 07:14:35 PDT 2018
Uhm, that is very strange. How did you setup GeoNode?
However, it seems to me that the issue is related to a missing dependency.
Try maybe by typing
pip install Paver==1.2.4
Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com>
ha scritto:
> Hi Alessio,
> The (pip install -r requirements.txt --upgrade) worked fine after
> another try.
> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
> This is the error produced:
> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
> Traceback (most recent call last):
> File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
> <module>
> from paver.tasks import main
> ImportError: No module named paver.tasks
> Any idea how to solve this?
> Thanks,
> Paulo
> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Paulo,
>> can you describe what's happening with a bit more detail?
>> That command should just start downloading the Python dependencies. If it
>> is stuck, most probably there's a problem reaching the PyPi repositories.
>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <pfrias82 at gmail.com>
>> ha scritto:
>>> Hi Alessio,
>>> I'm trying to install Geonode on Mac os X, following the tutorial you
>>> recommended (
>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>> When I run the command
>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>> Can you help me with some possible solution?
>>> Thanks,
>>> Paulo Frias
>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>> Hi Julierme,
>>>> please see my responses below.
>>>> "1 - can I make geonode-project my production environment? I meant run
>>>> GeoNode-Project as my production instance on the web."
>>>> Sure, but you will need to tweak a bit security options and settings in
>>>> order to secure and optimize your instance. Especially important are the
>>>> admin passwords and openid keys. This is valid in any case though.
>>>> "2 - do I need GeoNode Core to run together with GeoNode-Project?"
>>>> geonode-project makes use of geonode-core as a dependency. Until we do
>>>> final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>>>> geonode-project runs independently, but it still needs geonode as a
>>>> dependency. However by using it, you won't touch the geonode-core. This
>>>> will allow you to easily keep it up to date with the development version,
>>>> without clashes.
>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>>>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>>>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>> The tutorial and the documentation in general is outdated. We are
>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>> cleanup it. I'm very sorry about that.
>>>> We will try to do it when we start officially the release process.
>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>> Hi Alessio,
>>>>> I would like to make some questions related to Annalisa's installation
>>>>> question. I installed geonode-project only to customize the look.
>>>>> Now:
>>>>> Thank you very much for your time in advance
>>>>> Kind regards
>>>>> Julierme
>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>> Thanks for the tip!
>>>>>> Annalisa
>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>> Yes, absolutely. Currently, the deb installation is the most buggy
>>>>>>> and unstable one.
>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>> changing the files or the templates.
>>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>> Ok, thank you so much.
>>>>>>>> So you advise against the deb package installation, also if I don't
>>>>>>>> think to develop on geonode, only to customize the look?
>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>>>> following the procedure here
>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>> that case, follow the instructions here
>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>> want to evaluate.
>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>> Please someone may confirm that installation by deb packages,
>>>>>>>>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>>> What advantages does have VM Setup with VirtualBox installation (
>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>> Thank you for any hint.
>>>>>>>>>> Annalisa
>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>> Hi all.
>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>> production, currently?
>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>>>>> apt-get, following these commands:
>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>> Then I had installed geonode-project for a few changes in logos,
>>>>>>>>>>> colors and so on:
>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>> -epy,rst
>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>> Thank you,
>>>>>>>>>>> Annalisa
>>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> Founder/Technical Lead
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>> phone: +39 0584 962313
>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>> mob: +39 331 6233686
>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/96938dea/attachment-0001.html>
More information about the geonode-users
