[GeoNode-users] Best way to install geonode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Oct 26 07:21:38 PDT 2018
>From the link you sent to me, did you run also this one?
pip install -e . --upgrade
Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com>
ha scritto:
> I've followed this instructions
> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
> After "pip install Paver==1.2.4"
> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
> Build failed: Unknown task: reset
> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Uhm, that is very strange. How did you setup GeoNode?
>> However, it seems to me that the issue is related to a missing dependency.
>> Try maybe by typing
>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com>
>> ha scritto:
>>> Hi Alessio,
>>> The (pip install -r requirements.txt --upgrade) worked fine after
>>> another try.
>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>> This is the error produced:
>>> reset
>>> Traceback (most recent call last):
>>> File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
>>> <module>
>>> from paver.tasks import main
>>> ImportError: No module named paver.tasks
>>> Any idea how to solve this?
>>> Thanks,
>>> Paulo
>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>> Hi Paulo,
>>>> can you describe what's happening with a bit more detail?
>>>> That command should just start downloading the Python dependencies. If
>>>> it is stuck, most probably there's a problem reaching the PyPi repositories.
>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>> pfrias82 at gmail.com> ha scritto:
>>>>> Hi Alessio,
>>>>> I'm trying to install Geonode on Mac os X, following the tutorial you
>>>>> recommended (
>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>> When I run the command
>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>> Can you help me with some possible solution?
>>>>> Thanks,
>>>>> Paulo Frias
>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>> Hi Julierme,
>>>>>> please see my responses below.
>>>>>> "1 - can I make geonode-project my production environment? I meant
>>>>>> run GeoNode-Project as my production instance on the web."
>>>>>> Sure, but you will need to tweak a bit security options and settings
>>>>>> in order to secure and optimize your instance. Especially important are the
>>>>>> admin passwords and openid keys. This is valid in any case though.
>>>>>> "2 - do I need GeoNode Core to run together with GeoNode-Project?"
>>>>>> geonode-project makes use of geonode-core as a dependency. Until we
>>>>>> do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>>>>>> geonode-project runs independently, but it still needs geonode as a
>>>>>> dependency. However by using it, you won't touch the geonode-core. This
>>>>>> will allow you to easily keep it up to date with the development version,
>>>>>> without clashes.
>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>>>>>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>>>>>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>> The tutorial and the documentation in general is outdated. We are
>>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>>> cleanup it. I'm very sorry about that.
>>>>>> We will try to do it when we start officially the release process.
>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>> Hi Alessio,
>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>> look.
>>>>>>> Now:
>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?
>>>>>>> Thank you very much for your time in advance
>>>>>>> Kind regards
>>>>>>> Julierme
>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>> Thanks for the tip!
>>>>>>>> Annalisa
>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most buggy
>>>>>>>>> and unstable one.
>>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>>> changing the files or the templates.
>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>>> don't think to develop on geonode, only to customize the look?
>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>>>>>> following the procedure here
>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>> want to evaluate.
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>> Please someone may confirm that installation by deb packages,
>>>>>>>>>>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox installation
>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>> Annalisa
>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>>>>>>> apt-get, following these commands:
>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>> -epy,rst
>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>> notizia.
>>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/420ea2da/attachment-0001.html>
More information about the geonode-users
