[GeoNode-users] Best way to install geonode
Paulo Frias pfrias82 at gmail.com
Fri Oct 26 07:24:04 PDT 2018
Yes, but after that I had to downgrade some python packages.
On Fri, 26 Oct 2018 at 15:21, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> From the link you sent to me, did you run also this one?
> pip install -e . --upgrade
> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com>
> ha scritto:
>> I've followed this instructions
>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>> After "pip install Paver==1.2.4"
>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
>> Build failed: Unknown task: reset
>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>> Uhm, that is very strange. How did you setup GeoNode?
>>> However, it seems to me that the issue is related to a missing
>>> dependency.
>>> Try maybe by typing
>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com>
>>> ha scritto:
>>>> Hi Alessio,
>>>> The  (pip install -r requirements.txt --upgrade) worked fine after
>>>> another try.
>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>> This is the error produced:
>>>> reset
>>>> Traceback (most recent call last):
>>>>   File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
>>>> <module>
>>>>     from paver.tasks import main
>>>> ImportError: No module named paver.tasks
>>>> Any idea how to solve this?
>>>> Thanks,
>>>> Paulo
>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>> Hi Paulo,
>>>>> can you describe what's happening with a bit more detail?
>>>>> That command should just start downloading the Python dependencies. If
>>>>> it is stuck, most probably there's a problem reaching the PyPi repositories.
>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>> pfrias82 at gmail.com> ha scritto:
>>>>>> Hi Alessio,
>>>>>> I'm trying to install Geonode on Mac os X, following the tutorial you
>>>>>> recommended (
>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>>> When I run the command
>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>> Can you help me with some possible solution?
>>>>>> Thanks,
>>>>>> Paulo Frias
>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>> Hi Julierme,
>>>>>>> please see my responses below.
>>>>>>> "1 - can I make geonode-project my production environment? I meant
>>>>>>> run GeoNode-Project as my production instance on the web."
>>>>>>> Sure, but you will need to tweak a bit security options and settings
>>>>>>> in order to secure and optimize your instance. Especially important are the
>>>>>>> admin passwords and openid keys. This is valid in any case though.
>>>>>>> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
>>>>>>> geonode-project makes use of geonode-core as a dependency. Until we
>>>>>>> do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode
>>>>>>> Core?"
>>>>>>> geonode-project runs independently, but it still needs geonode as a
>>>>>>> dependency. However by using it, you won't touch the geonode-core. This
>>>>>>> will allow you to easily keep it up to date with the development version,
>>>>>>> without clashes.
>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8
>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>> The tutorial and the documentation in general is outdated. We are
>>>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>> We will try to do it when we start officially the release process.
>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>>> Hi Alessio,
>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>> look.
>>>>>>>> Now:
>>>>>>>> 3 - GeoNode-Project can run independently, no need for GeoNode Core?
>>>>>>>> Thank you very much for your time in advance
>>>>>>>> Kind regards
>>>>>>>> Julierme
>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>>> Thanks for the tip!
>>>>>>>>> Annalisa
>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most
>>>>>>>>>> buggy and unstable one.
>>>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>>>> changing the files or the templates.
>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>>>> don't think to develop on geonode,  only to customize the look?
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>>>>>>> following the procedure here
>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>>> Please someone may confirm that installation by deb packages,
>>>>>>>>>>>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox
>>>>>>>>>>>>> installation (
>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it
>>>>>>>>>>>>> recommended install geonode-project and create a template, in similar way
>>>>>>>>>>>>> than once? Because in
>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed
>>>>>>>>>>>>>> via apt-get, following these commands:
>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>>>  -epy,rst
>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>> notizia.
>>>>>>>>>>>> This email is intended only for the person or entity to which
>>>>>>>>>>>> it is addressed and may contain information that is privileged,
>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/a8543dfb/attachment-0001.html>
More information about the geonode-users mailing list
