[GeoNode-users] Best way to install geonode
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Fri Oct 26 08:45:42 PDT 2018
If I remember correctly. I’ve got it running with:
brew unlink gdal
brew tap osgeo/osgeo4mac && brew tap --repair
brew install jasper netcdf # gdal dependencies
brew install gdal2 --with-armadillo \
--with-complete --with-libkml --with-unsupported
brew link --force gdal2
Cheers,
Toni
> Am 26.10.2018 um 17:04 schrieb Paulo Frias <pfrias82 at gmail.com>:
> Yes, with OSX. I had also issues with gdal and because of that I'm trying with Anaconda to set the virtual environment and to install gdal through "conda install gdal".
> On Fri, 26 Oct 2018 at 15:58, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Great.
> Are you on OSX? If so I’ ve lately had some issues with brew packages / gdal.
> Let me know if you encounter further dependency errors.
> Cheers,
> Toni
>> Am 26.10.2018 um 16:53 schrieb Paulo Frias <pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>>:
>> Probably a good shot in the dark. I've named it "geonode" and not "my_genode" but I just erased the virtual environment to start over again.
>> On Fri, 26 Oct 2018 at 15:42, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
>> Hi Paulo,
>> Just a shot in the dark.
>> When you started your project from template did you name it my_geonode?
>> If not you should double check to use the correct settings:
>> DJANGO_SETTINGS_MODULE=your_namend_geonode.settings paver reset
>> Cheers,
>> Toni
>>> Am 26.10.2018 um 16:21 schrieb geonode-users-request at lists.osgeo.org <mailto:geonode-users-request at lists.osgeo.org>:
>>> Send geonode-users mailing list submissions to
>>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>> geonode-users-owner at lists.osgeo.org <mailto:geonode-users-owner at lists.osgeo.org>
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of geonode-users digest..."
>>> Today's Topics:
>>> 1. Re: Best way to install geonode (Alessio Fabiani)
>>> Message: 1
>>> Date: Fri, 26 Oct 2018 16:21:38 +0200
>>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>>
>>> To: Paulo Frias <pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>>
>>> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>>, geonode-users
>>> <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
>>> Subject: Re: [GeoNode-users] Best way to install geonode
>>> Message-ID:
>>> <CAM7ZvLLpVZXQauUZ9OmQNZLWB6iCtP=BP-cK82HDgUNvsLgZUQ at mail.gmail.com <mailto:BP-cK82HDgUNvsLgZUQ at mail.gmail.com>>
>>> Content-Type: text/plain; charset="utf-8"
>>>> From the link you sent to me, did you run also this one?
>>> pip install -e . --upgrade
>>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>>
>>> ha scritto:
>>>> I've followed this instructions
>>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project <https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project>
>>>> After "pip install Paver==1.2.4"
>>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
>>>> Build failed: Unknown task: reset
>>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>> wrote:
>>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>>> However, it seems to me that the issue is related to a missing dependency.
>>>>> Try maybe by typing
>>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>>
>>>>> ha scritto:
>>>>>> Hi Alessio,
>>>>>> The (pip install -r requirements.txt --upgrade) worked fine after
>>>>>> another try.
>>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>>> This is the error produced:
>>>>>> reset
>>>>>> Traceback (most recent call last):
>>>>>> File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
>>>>>> <module>
>>>>>> from paver.tasks import main
>>>>>> ImportError: No module named paver.tasks
>>>>>> Any idea how to solve this?
>>>>>> Thanks,
>>>>>> Paulo
>>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>>> Hi Paulo,
>>>>>>> can you describe what's happening with a bit more detail?
>>>>>>> That command should just start downloading the Python dependencies. If
>>>>>>> it is stuck, most probably there's a problem reaching the PyPi repositories.
>>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>>> pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>> ha scritto:
>>>>>>>> Hi Alessio,
>>>>>>>> I'm trying to install Geonode on Mac os X, following the tutorial you
>>>>>>>> recommended (
>>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project <https://github.com/GeoNode/geonode-project#create-a-custom-project>).
>>>>>>>> When I run the command
>>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>>> Can you help me with some possible solution?
>>>>>>>> Thanks,
>>>>>>>> Paulo Frias
>>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>>> Hi Julierme,
>>>>>>>>> please see my responses below.
>>>>>>>>> "1 - can I make geonode-project my production environment? I meant
>>>>>>>>> run GeoNode-Project as my production instance on the web."
>>>>>>>>> Sure, but you will need to tweak a bit security options and settings
>>>>>>>>> in order to secure and optimize your instance. Especially important are the
>>>>>>>>> admin passwords and openid keys. This is valid in any case though.
>>>>>>>>> "2 - do I need GeoNode Core to run together with GeoNode-Project?"
>>>>>>>>> geonode-project makes use of geonode-core as a dependency. Until we
>>>>>>>>> do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>>>>>>>>> geonode-project runs independently, but it still needs geonode as a
>>>>>>>>> dependency. However by using it, you won't touch the geonode-core. This
>>>>>>>>> will allow you to easily keep it up to date with the development version,
>>>>>>>>> without clashes.
>>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>>
>>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>>>>>>>>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>>>>>>>>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>>> The tutorial and the documentation in general is outdated. We are
>>>>>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>>> We will try to do it when we start officially the release process.
>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>>> juliermeopensourcedeveloper at gmail.com <mailto:juliermeopensourcedeveloper at gmail.com>> ha scritto:
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>>> look.
>>>>>>>>>> Now:
>>>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?
>>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>>> Kind regards
>>>>>>>>>> Julierme
>>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>>> annalisa.schiavon at gmail.com <mailto:annalisa.schiavon at gmail.com>> wrote:
>>>>>>>>>>> Thanks for the tip!
>>>>>>>>>>> Annalisa
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>>> alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>> ha scritto:
>>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most buggy
>>>>>>>>>>>> and unstable one.
>>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>>> annalisa.schiavon at gmail.com <mailto:annalisa.schiavon at gmail.com>> ha scritto:
>>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>>>>>> don't think to develop on geonode, only to customize the look?
>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>>>>>>>>> following the procedure here
>>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing <https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing>
>>>>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>>>>> Please someone may confirm that installation by deb packages,
>>>>>>>>>>>>>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox installation
>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html <http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html>)?
>>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html>
>>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>>>>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>>>>>>>>>> Because in https://github.com/GeoNode/geonode-project <https://github.com/GeoNode/geonode-project> I find
>>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>>>>>>>>>> apt-get, following these commands:
>>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip <https://github.com/GeoNode/geonode-project/archive/master.zip>
>>>>>>>>>>>>>>>> -epy,rst
>>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>>> http://goo.gl/it488V <http://goo.gl/it488V> for more information.
>>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>>>>>> http://www.geo-solutions.it <http://www.geo-solutions.it/>
>>>>>>>>>>>>>> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
>>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V <http://goo.gl/it488V>
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/420ea2da/attachment.html <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/420ea2da/attachment.html>>
>>> Subject: Digest Footer
>>> End of geonode-users Digest, Vol 45, Issue 108
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/f8f772d1/attachment-0001.html>
More information about the geonode-users
