[GeoNode-users] Best way to install geonode
Paulo Frias pfrias82 at gmail.com
Fri Oct 26 08:56:56 PDT 2018
In the last step:
(my_geonode) bash-3.2$ brew link --force gdal2
Error: No such keg: /usr/local/Cellar/gdal2
On Fri, 26 Oct 2018 at 16:45, Toni Schönbuchner <toni.schoenbuchner at csgis.de>
wrote:
> If I remember correctly. I’ve got it running with:
> brew unlink gdal
> brew tap osgeo/osgeo4mac && brew tap --repair
> brew install jasper netcdf # gdal dependencies
> brew install gdal2 --with-armadillo \
> --with-complete --with-libkml --with-unsupported
> Cheers,
> Toni
> Am 26.10.2018 um 17:04 schrieb Paulo Frias <pfrias82 at gmail.com>:
> Yes, with OSX. I had also issues with gdal and because of that I'm trying
> with Anaconda to set the virtual environment and to install gdal through
> "conda install gdal".
> On Fri, 26 Oct 2018 at 15:58, Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Great.
>> Are you on OSX? If so I’ ve lately had some issues with brew packages /
>> gdal.
>> Let me know if you encounter further dependency errors.
>> Cheers,
>> Toni
>> Am 26.10.2018 um 16:53 schrieb Paulo Frias <pfrias82 at gmail.com>:
>> Probably a good shot in the dark.  I've named it "geonode" and not
>> "my_genode" but I just erased the virtual environment to start over again.
>> On Fri, 26 Oct 2018 at 15:42, Toni Schönbuchner <
>>> Hi Paulo,
>>> Just a shot in the dark.
>>> When you started your project from template did you name it my_geonode?
>>> If not you should double check to use the correct settings:
>>> DJANGO_SETTINGS_MODULE=*your_namend_geonode.settings *paver reset
>>> Cheers,
>>> Toni
>>> Am 26.10.2018 um 16:21 schrieb geonode-users-request at lists.osgeo.org:
>>> Send geonode-users mailing list submissions to
>>> geonode-users at lists.osgeo.org
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>> geonode-users-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of geonode-users digest..."
>>> Today's Topics:
>>>   1. Re: Best way to install geonode (Alessio Fabiani)
>>> Message: 1
>>> Date: Fri, 26 Oct 2018 16:21:38 +0200
>>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>>> To: Paulo Frias <pfrias82 at gmail.com>
>>> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it>,  geonode-users
>>> <geonode-users at lists.osgeo.org>
>>> Subject: Re: [GeoNode-users] Best way to install geonode
>>> Message-ID:
>>> <CAM7ZvLLpVZXQauUZ9OmQNZLWB6iCtP=BP-cK82HDgUNvsLgZUQ at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> From the link you sent to me, did you run also this one?
>>> pip install -e . --upgrade
>>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com
>>> ha scritto:
>>> I've followed this instructions
>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>>> After "pip install Paver==1.2.4"
>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver
>>> reset
>>> Build failed: Unknown task: reset
>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>> Uhm, that is very strange. How did you setup GeoNode?
>>> However, it seems to me that the issue is related to a missing
>>> dependency.
>>> Try maybe by typing
>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com
>>> ha scritto:
>>> Hi Alessio,
>>> The  (pip install -r requirements.txt --upgrade) worked fine after
>>> another try.
>>> Now I'm stucked in the command
>>> (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>> This is the error produced:
>>> reset
>>> Traceback (most recent call last):
>>>  File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
>>> <module>
>>>    from paver.tasks import main
>>> ImportError: No module named paver.tasks
>>> Any idea how to solve this?
>>> Thanks,
>>> Paulo
>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>> Hi Paulo,
>>> can you describe what's happening with a bit more detail?
>>> That command should just start downloading the Python dependencies. If
>>> it is stuck, most probably there's a problem reaching the PyPi
>>> repositories.
>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>> pfrias82 at gmail.com> ha scritto:
>>> Hi Alessio,
>>> I'm trying to install Geonode on Mac os X, following the tutorial you
>>> recommended (
>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>> When I run the command
>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>> Can you help me with some possible solution?
>>> Thanks,
>>> Paulo Frias
>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>> Hi Julierme,
>>> please see my responses below.
>>> "1 - can I make geonode-project my production environment? I meant
>>> run GeoNode-Project as my production instance on the web."
>>> Sure, but you will need to tweak a bit security options and settings
>>> in order to secure and optimize your instance. Especially important are
>>> the
>>> admin passwords and openid keys. This is valid in any case though.
>>> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
>>> geonode-project makes use of geonode-core as a dependency. Until we
>>> do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>> repositories, yes, you'll need the geonode-core among the python deps.
>>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>>> geonode-project runs independently, but it still needs geonode as a
>>> dependency. However by using it, you won't touch the geonode-core. This
>>> will allow you to easily keep it up to date with the development version,
>>> without clashes.
>>> "4 - If I am not misunderstanding, the tutorial in here <
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html
>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the
>>> same
>>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>>> The tutorial and the documentation in general is outdated. We are
>>> lacking of resources and, unfortunately, we did not found time yet to
>>> cleanup it. I'm very sorry about that.
>>> We will try to do it when we start officially the release process.
>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>> Hi Alessio,
>>> I would like to make some questions related to Annalisa's
>>> installation question. I installed geonode-project only to customize the
>>> look.
>>> Now:
>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?
>>> Thank you very much for your time in advance
>>> Kind regards
>>> Julierme
>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>> annalisa.schiavon at gmail.com> wrote:
>>> Thanks for the tip!
>>> Annalisa
>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> Yes, absolutely. Currently, the deb installation is the most buggy
>>> and unstable one.
>>> It is worth notice that now GeoNode provides natively a way to
>>> customize the interface, at least some part of it, without the need of
>>> changing the files or the templates.
>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>> annalisa.schiavon at gmail.com> ha scritto:
>>> Ok, thank you so much.
>>> So you advise against the deb package installation, also if I
>>> don't think to develop on geonode,  only to customize the look?
>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>> If you want to install geonode for development, I would suggest
>>> following the procedure here
>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>> If you want to start customizing your own portal (but still
>>> develop it), I would suggest starting from a geonode-project template. In
>>> that case, follow the instructions here
>>> Otherwise, you can virtual machines either using vagrant or
>>> docker. There are several ways and configurations around that you might
>>> want to evaluate.
>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>> Please someone may confirm that installation by deb packages,
>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>> What advantages does have VM Setup with VirtualBox installation
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html
>>> And than the installation step by step described in
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>> If I want to changes logos, colors and texts, is it recommended
>>> install geonode-project and create a template, in similar way than once?
>>> Because in https://github.com/GeoNode/geonode-project I find
>>> instructions only for a Python virtual environment.
>>> Thank you for any hint.
>>> Annalisa
>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>> Hi all.
>>> What is the best way to install geonode on Ubuntu for
>>> production, currently?
>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>> apt-get, following these commands:
>>> sudo add-apt-repository ppa:geonode/stable
>>> sudo apt-get update
>>> sudo apt-get install geonode
>>> Then I had installed geonode-project for a few changes in
>>> logos, colors and so on:
>>> django-admin startproject geoportale20 --template=
>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>> -epy,rst
>>> sudo pip install -e geoportale20
>>> There are some procedures to migrate data from 2.4 to 2.8
>>> (jumping the 2.6 release)?
>>> Thank you,
>>> Annalisa
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati
>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente
>>> email
>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo
>>> scrivente.
>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>> notizia.
>>> This email is intended only for the person or entity to which it
>>> is addressed and may contain information that is privileged, confidential
>>> or otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of
>>> this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake,
>>> please
>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali
>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
>>> “GDPR”),
>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> notizia.
>>> this
>>> please
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> “GDPR”),
>>> notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> this
>>> please
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> notizia.
>>> this
>>> please
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> notizia.
>>> this
>>> please
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> UE
>>> notizia.
>>> this
>>> please
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <
>>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/420ea2da/attachment.html
>>> Subject: Digest Footer
>>> End of geonode-users Digest, Vol 45, Issue 108
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/f3f8d748/attachment-0001.html>
More information about the geonode-users mailing list
