[GeoNode-users] Info about updatelayers command?
francesco bartoli
xbartolone at gmail.com
Fri Oct 26 15:36:26 PDT 2018
Yes Alessio but I guessed Ana would be ended up with a merge issue. One
easy solution if settings.py is the only file edited would be to copy it
somewhere else then run
*git checkout*
before
*git pull*
finally overwrite settings.py with the copied one.
Il giorno ven 26 ott 2018 alle ore 20:00 Ana Boljevic <ana.boljevic at cedis.me>
ha scritto:
> Sorry,
> we have error, I didn't notice at first:
> geonode at testgis:~/geonode$ docker exec -i -t django4geonode bash
> root at 5058e8a1637f:/usr/src/app# git pull
> remote: Enumerating objects: 321, done.
> remote: Counting objects: 100% (321/321), done.
> remote: Compressing objects: 100% (20/20), done.
> remote: Total 620 (delta 308), reused 307 (delta 301), pack-reused 299
> Receiving objects: 100% (620/620), 3.66 MiB | 812.00 KiB/s, done.
> Resolving deltas: 100% (441/441), completed with 126 local objects.
> From https://github.com/GeoNode/geonode
> 33aa3e6..34ac634 master -> origin/master
> 2ea8bc6..89efc19 2.8.x -> origin/2.8.x
> * [new branch] ISSUE_4025 -> origin/ISSUE_4025
> Updating 33aa3e6..34ac634
> error: Your local changes to the following files would be overwritten by
> merge:
> geonode/settings.py
> Please, commit your changes or stash them before you can merge.
> Aborting
> Regards,
> Ana
> -------- Original message --------
> From: Ana Boljevic <ana.boljevic at cedis.me>
> Date: 10/26/18 19:50 (GMT+01:00)
> To: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Cc: geonode-users-bounces at lists.osgeo.org, geonode-users <
> geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] Info about updatelayers command?
> Dear Alessio,
> We have done:
> git pull
> exit
> docker-compose stop
> docker-compose up --no-build -d
> and after that, from django4geonode container error still remains:
> root at 5058e8a1637f:/usr/src/app# python manage.py updatelayers
> Inspecting the available layers in GeoServer ...
> Found 6 layers, starting processing
> Stopping process because --ignore-errors was not set and an error was
> found.
> Traceback (most recent call last):
> File "manage.py", line 29, in <module>
> execute_from_command_line(sys.argv)
> File
> "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 364, in execute_from_command_line
> utility.execute()
> File
> line 356, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File "/usr/local/lib/python2.7/site-packages/django/core/management/
> base.py", line 283, in run_from_argv
> self.execute(*args, **cmd_options)
> base.py", line 330, in execute
> output = self.handle(*args, **options)
> File "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py",
> line 124, in handle
> execute_signals=True)
> File "/usr/src/app/geonode/geoserver/helpers.py", line 637, in gs_slurp
> layer.set_permissions(perm_spec)
> File "/usr/src/app/geonode/security/models.py", line 216, in
> set_permissions
> sync_geofence_with_guardian(self.layer, perms, group=group)
> File "/usr/src/app/geonode/decorators.py", line 44, in wrapper
> return func(*args, **kwargs)
> File "/usr/src/app/geonode/security/utils.py", line 392, in
> _update_geofence_rule(layer.name, layer.workspace, service)
> File "/usr/src/app/geonode/security/utils.py", line 563, in
> raise RuntimeError(msg)
> Exception: ('Failed to process OPSTINE', RuntimeError("Could not ADD
> GeoServer User None Rule for Layer u'OPSTINE'",))
> Regards,
> Ana
> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Date: 10/26/18 15:51 (GMT+01:00)
> To: Ana Boljevic <ana.boljevic at cedis.me>
> Cc: Francesco Bartoli <xbartolone at gmail.com>,
> Hi Ana,
> In order to update the GeoNode on your GeoNode instance, I guess you can
> try something like
> git pull
> exit
> docker-compose stop
> @Francesco Bartoli <xbartolone at gmail.com> can you confirm?
> Il giorno ven 26 ott 2018 alle ore 15:45 Ana Boljevic <
> ana.boljevic at cedis.me> ha scritto:
>> Sorry, but my docker experience is weak. I don't know how to solve the
>> problem.
>> I want to apply fix from github without loosing my data. Is it possible?
>> Can you please write commands?
>> Regards,
>> Ana
>> From: Francesco Bartoli <xbartolone at gmail.com>
>> Date: 10/26/18 14:25 (GMT+01:00)
>> Cc: geonode-users <geonode-users at lists.osgeo.org>,
>> Subject: RE: [GeoNode-users] Info about updatelayers command?
>> If you already cloned it then you can just execute
>> *git pull origin master*
>> Rebuilding all the containers is not terrible until you don’t remove the
>> volumes.
>> Hope this helps
>> Francesco
>> On 26 Oct 2018, 12:54 +0200, Ana Boljevic <ana.boljevic at cedis.me>, wrote:
>> Dear Francesco,
>> Can you please be more specific.
>> Should we pull latest code with this command:
>> git clone https://github.com/GeoNode/geonode.git
>> Do I have to rebuild all containers or can I rebuild only django4geonode ?
>> Will I lose all of my settings and data by doing this ?
>> Regards,
>> *Ana Boljević*
>> Direkcija za razvoj, pristup mreži i ICT
>> Sektor za ICT
>> Služba za GIS i tehničku bazu podataka
>> *[image: CEDIS]*
>> *DOO „Crnogorski elektrodistributivni sistem“ Podgorica*
>> Ivana Milutinovića br.12, Podgorica
>> Tel: +382 20 408 473
>> *www.cedis.me <http://www.cedis.me/>*
>> [image: jelkica]Please do not print this e-mail unless you really need to
>> *From:* francesco bartoli [mailto:xbartolone at gmail.com]
>> *Sent:* Friday, October 26, 2018 11:12 AM
>> *To:* Ana Boljevic <ana.boljevic at cedis.me>
>> *Cc:* Michael Fedak <mikefedak at gmail.com>; geonode-users <
>> geonode-users at lists.osgeo.org>; geonode-users-bounces at lists.osgeo.org
>> *Subject:* Re: [GeoNode-users] Info about updatelayers command?
>> If you apply changes or you have got new updates from the repo then you
>> have to rebuild the image so please try to add and use the option "--build"
>> that I mentioned above.
>> However if you are going to modify geonode and don't want to contribute
>> back with pull requests then the suggested method would be to use a
>> geonode-project.
>> Il giorno ven 26 ott 2018 alle ore 09:46 Ana Boljevic <
>> Dear Francesco,
>> We did the following 15 days ago:
>> cd /home/geonode/geonode
>> docker-compose up -d
>> In meantime, we make changes on containers and then commit those changes.
>> Can you please explain in details how to apply fix from github ?
>> Regards
>> Ana
>> From: francesco bartoli <xbartolone at gmail.com>
>> Date: 10/26/18 08:50 (GMT+01:00)
>> Cc: Michael Fedak <mikefedak at gmail.com>, geonode-users <
>> geonode-users at lists.osgeo.org>, geonode-users-bounces at lists.osgeo.org
>> Hi Ana,
>> can you please explain what did you do? The better to try is to pull the
>> latest code from github and then run "docker-compose up --build" regardless
>> of the version. The fix is for sure also in master.
>> Hope this helps,
>> Francesco
>> Il giorno ven 26 ott 2018 alle ore 07:16 Ana Boljevic <
>> Dears,
>> We have tried to implement solution by Mr. Fabiani:
>> https://github.com/GeoNode/geonode/pull/3986/files
>> but after we have manually changed those 4 files django4geonode
>> containers can't bring up anymore.
>> Does this solution apply also for GeoNode version 2.10rc4 ?
>> Thanks in advance.
>> Regards,
>> *Ana Boljević*
>> Sektor za ICT
>> *From:* Michael Fedak [mailto:mikefedak at gmail.com]
>> *Sent:* Monday, October 22, 2018 3:20 PM
>> *Cc:* geonode-users-bounces at lists.osgeo.org; geonode-users <
>> I had a similar issue on 2.8 last week. See here for the
>> discussion/fix: https://github.com/GeoNode/geonode/issues/3984
>> On Mon, Oct 22, 2018 at 7:25 AM Ana Boljevic <ana.boljevic at cedis.me>
>> wrote:
>> Dear Geonode community,
>> If someone knows little bit more about this, we would appreciate your
>> help J Explanation below:
>> We have installed Geonode on docker (version 2.10rc4). We imported first
>> kml layer but updatelayers (from inside of django4geonode container) report
>> problem "Could not ADD GeoServer User None Rule for Layer":
>> root at 5058e8a1637f:/usr/src/app# ./manage.py updatelayers
>> Found 1 layers, starting processing
>> found.
>> File "./manage.py", line 29, in <module>
>> File
>> utility.execute()
>> File
>> File
>> "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
>> File
>> File
>> "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line
>> 124, in handle
>> set_permissions
>> Exception: ('Failed to process novi_r6_Slijepac_most_10kV',
>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>> u'novi_r6_Slijepac_most_10kV'",))
>> But the same command from celery4geonode container has different output:
>> root at bca672a5673d:/usr/src/app# ./manage.py updatelayers
>> /usr/local/lib/python2.7/site-packages/owslib/iso.py:117: FutureWarning:
>> the .identification and .serviceidentification properties will merge into
>> .identification being a list of properties. This is currently implemented
>> in .identificationinfo. Please see
>> https://github.com/geopython/OWSLib/issues/38 for more information
>> FutureWarning)
>> /usr/local/lib/python2.7/site-packages/owslib/iso.py:482: FutureWarning:
>> The .keywords and .keywords2 properties will merge into the .keywords
>> property in the future, with .keywords becoming a list of MD_Keywords
>> instances. This is currently implemented in .keywords2. Please see
>> https://github.com/geopython/OWSLib/issues/301 for more information
>> FutureWarning)
>> /usr/local/lib/python2.7/site-packages/geoserver/style.py:73:
>> FutureWarning: The behavior of this method will change in future versions.
>> Use specific 'len(elem)' or 'elem is not None' test instead.
>> if not user_style:
>> /usr/local/lib/python2.7/site-packages/geoserver/style.py:77:
>> if user_style:
>> ... Creating Thumbnail for Layer [geonode:OPSTINE]
>> [updated] Layer OPSTINE (1/6)
>> [geonode:novi_novi_r6_Pavino_Polje_10kV_izmijenjen]
>> [updated] Layer novi_novi_r6_Pavino_Polje_10kV_izmijenjen (2/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Ambarine_Przista_10kV]
>> [created] Layer novi_r6_Ambarine_Przista_10kV (3/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Gimnazija_10_kV]
>> [updated] Layer novi_r6_Gimnazija_10_kV (4/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Planinica_10_kV]
>> [updated] Layer novi_r6_Planinica_10_kV (5/6)
>> ... Creating Thumbnail for Layer [geonode:novi_r6_Rasovo_10kV]
>> [updated] Layer novi_r6_Rasovo_10kV (6/6)
>> Finished processing 6 layers in 53.0 seconds.
>> 1 Created layers
>> 5 Updated layers
>> 0 Failed layers
>> 8.830000 seconds per layer
>> *Is such behavior normal ?*
>> Thanks in advance.
>> Kind regards,
>> *Ana Boljević*
>> Sektor za ICT
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181027/2bcdc923/attachment-0001.html>
More information about the geonode-users
