[GeoNode-users] Info about updatelayers command?
Ana Boljevic ana.boljevic at cedis.me
Sun Oct 28 04:54:40 PDT 2018
Dear Francesco and Alessio,
We have moved all changed files in /tmp folder of the host, git pull, put moved files back in thair original path and than
docker-compose stop
docker-compose up --no-build -d
but now django container can't bring up
root at 5058e8a1637f:/usr/src/app# git checkout
M       docker-compose.yml
M       entrypoint.sh<http://entrypoint.sh>
M       geonode/settings.py<http://settings.py>
M       scripts/docker/env/production/celery.env
M       scripts/docker/env/production/django.env
M       scripts/docker/env/production/geoserver.env
geonode at testgis:/tmp$ docker cp 5058e8a1637f:/usr/src/app/entrypoint.sh<http://entrypoint.sh> /tmp
geonode at testgis:/tmp$ docker cp 5058e8a1637f:/usr/src/app/geonode/settings.py<http://settings.py> /tmp
geonode at testgis:/tmp$ docker cp 5058e8a1637f:/usr/src/app/scripts/docker/env/production/celery.env /tmp
geonode at testgis:/tmp$ docker cp 5058e8a1637f:/usr/src/app/scripts/docker/env/production/django.env /tmp
geonode at testgis:/tmp$ docker cp 5058e8a1637f:/usr/src/app/scripts/docker/env/production/geoserver.env /tmp
rm docker-compose.yml entrypoint.sh<http://entrypoint.sh> geonode/settings.py<http://settings.py> scripts/docker/env/production/celery.env scripts/docker/env/production/django.env scripts/docker/env/production/geoserver.env
git pull
geonode at testgis:~/geonode$ docker cp /tmp/docker-compose.yml 5058e8a1637f:/usr/src/app/docker-compose.yml
geonode at testgis:~/geonode$ docker cp /tmp/entrypoint.sh<http://entrypoint.sh> 5058e8a1637f:/usr/src/app/entrypoint.sh<http://entrypoint.sh>
geonode at testgis:~/geonode$ docker cp /tmp/settings.py<http://settings.py> 5058e8a1637f:/usr/src/app/geonode/settings.py<http://settings.py>
geonode at testgis:~/geonode$ docker cp /tmp/celery.env 5058e8a1637f:/usr/src/app/scripts/docker/env/production/celery.env
geonode at testgis:~/geonode$ docker cp /tmp/django.env 5058e8a1637f:/usr/src/app/scripts/docker/env/production/django.env
geonode at testgis:~/geonode$ docker cp /tmp/geoserver.env 5058e8a1637f:/usr/src/app/scripts/docker/env/production/geoserver.env
docker-compose stop
Regards,
Ana
-------- Original message --------
Date: 10/27/18 00:36 (GMT+01:00)
To: Ana Boljevic <ana.boljevic at cedis.me>
Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it>, geonode-users-bounces at lists.osgeo.org, geonode-users <geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] Info about updatelayers command?
Yes Alessio but I guessed Ana would be ended up with a merge issue. One easy solution if settings.py is the only file edited would be to copy it somewhere else then run
git checkout
before
git pull
finally overwrite settings.py with the copied one.
Il giorno ven 26 ott 2018 alle ore 20:00 Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> ha scritto:
Sorry,
we have error, I didn't notice at first:
geonode at testgis:~/geonode$ docker exec -i -t django4geonode bash
root at 5058e8a1637f:/usr/src/app# git pull
remote: Enumerating objects: 321, done.
remote: Counting objects: 100% (321/321), done.
remote: Compressing objects: 100% (20/20), done.
remote: Total 620 (delta 308), reused 307 (delta 301), pack-reused 299
Receiving objects: 100% (620/620), 3.66 MiB | 812.00 KiB/s, done.
Resolving deltas: 100% (441/441), completed with 126 local objects.
From https://github.com/GeoNode/geonode
   33aa3e6..34ac634  master     -> origin/master
   2ea8bc6..89efc19  2.8.x      -> origin/2.8.x
 * [new branch]      ISSUE_4025 -> origin/ISSUE_4025
Updating 33aa3e6..34ac634
error: Your local changes to the following files would be overwritten by merge:
Please, commit your changes or stash them before you can merge.
Aborting
Regards,
Ana
From: Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>>
Date: 10/26/18 19:50 (GMT+01:00)
To: Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>
Cc: geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>, geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Dear Alessio,
We have done:
git pull
exit
docker-compose stop
and after that, from django4geonode container error still remains:
root at 5058e8a1637f:/usr/src/app# python manage.py<http://manage.py> updatelayers
Inspecting the available layers in GeoServer ...
Found 6 layers, starting processing
Stopping process because --ignore-errors was not set and an error was found.
  File "manage.py<http://manage.py>", line 29, in <module>
    execute_from_command_line(sys.argv)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 364, in execute_from_command_line
    utility.execute()
  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 356, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py<http://base.py>", line 283, in run_from_argv
    self.execute(*args, **cmd_options)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py<http://base.py>", line 330, in execute
    output = self.handle(*args, **options)
  File "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py<http://updatelayers.py>", line 124, in handle
    execute_signals=True)
  File "/usr/src/app/geonode/geoserver/helpers.py<http://helpers.py>", line 637, in gs_slurp
    layer.set_permissions(perm_spec)
  File "/usr/src/app/geonode/security/models.py<http://models.py>", line 216, in set_permissions
    sync_geofence_with_guardian(self.layer, perms, group=group)
  File "/usr/src/app/geonode/decorators.py<http://decorators.py>", line 44, in wrapper
    return func(*args, **kwargs)
  File "/usr/src/app/geonode/security/utils.py<http://utils.py>", line 392, in sync_geofence_with_guardian
    _update_geofence_rule(layer.name<http://layer.name>, layer.workspace, service)
  File "/usr/src/app/geonode/security/utils.py<http://utils.py>", line 563, in _update_geofence_rule
    raise RuntimeError(msg)
Exception: ('Failed to process OPSTINE', RuntimeError("Could not ADD GeoServer User None Rule for Layer u'OPSTINE'",))
Regards,
Ana
From: Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>
Date: 10/26/18 15:51 (GMT+01:00)
To: Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>>
Cc: Francesco Bartoli <xbartolone at gmail.com<mailto:xbartolone at gmail.com>>, geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>, geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Hi Ana,
In order to update the GeoNode on your GeoNode instance, I guess you can try something like
git pull
exit
docker-compose stop
@Francesco Bartoli<mailto:xbartolone at gmail.com> can you confirm?
Il giorno ven 26 ott 2018 alle ore 15:45 Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> ha scritto:
Sorry, but my docker experience is weak. I don't know how to solve the problem.
I want to apply fix from github without loosing my data. Is it possible?
Can you please write commands?
Regards,
Ana
From: Francesco Bartoli <xbartolone at gmail.com<mailto:xbartolone at gmail.com>>
Date: 10/26/18 14:25 (GMT+01:00)
Cc: geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>, geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>
Subject: RE: [GeoNode-users] Info about updatelayers command?
If you already cloned it then you can just execute
git pull origin master
Rebuilding all the containers is not terrible until you don’t remove the volumes.
Hope this helps
Francesco
On 26 Oct 2018, 12:54 +0200, Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>>, wrote:
Dear Francesco,
Can you please be more specific.
Should we pull latest code with this command:
git clone https://github.com/GeoNode/geonode.git
Do I have to rebuild all containers or can I rebuild only django4geonode ?
Will I lose all of my settings and data by doing this ?
Regards,
Ana Boljević
Direkcija za razvoj, pristup mreži i ICT
Sektor za ICT
Služba za GIS i tehničku bazu podataka
[CEDIS]
DOO „Crnogorski elektrodistributivni sistem“ Podgorica
Ivana Milutinovića br.12, Podgorica
Tel: +382 20 408 473
www.cedis.me<http://www.cedis.me/>
[jelkica]Please do not print this e-mail unless you really need to
From: francesco bartoli [mailto:xbartolone at gmail.com<mailto:xbartolone at gmail.com>]
Sent: Friday, October 26, 2018 11:12 AM
Cc: Michael Fedak <mikefedak at gmail.com<mailto:mikefedak at gmail.com>>; geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>; geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>
If you apply changes or you have got new updates from the repo then you have to rebuild the image so please try to add and use the option "--build" that I mentioned above.
However if you are going to modify geonode and don't want to contribute back with pull requests then the suggested method would be to use a geonode-project.
Il giorno ven 26 ott 2018 alle ore 09:46 Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> ha scritto:
Dear Francesco,
We did the following 15 days ago:
cd /home/geonode/geonode
docker-compose up -d
In meantime, we make changes on containers and then commit those changes.
Can you please explain in details how to apply fix from github ?
Regards
Ana
From: francesco bartoli <xbartolone at gmail.com<mailto:xbartolone at gmail.com>>
Date: 10/26/18 08:50 (GMT+01:00)
Cc: Michael Fedak <mikefedak at gmail.com<mailto:mikefedak at gmail.com>>, geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>, geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>
Hi Ana,
can you please explain what did you do? The better to try is to pull the latest code from github and then run "docker-compose up --build" regardless of the version. The fix is for sure also in master.
Hope this helps,
Francesco
Il giorno ven 26 ott 2018 alle ore 07:16 Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> ha scritto:
Dears,
We have tried to implement solution by Mr. Fabiani:
https://github.com/GeoNode/geonode/pull/3986/files
but after we have manually changed those 4 files django4geonode containers can't bring up anymore.
Does this solution apply also for GeoNode version 2.10rc4 ?
Thanks in advance.
Regards,
Ana Boljević
Sektor za ICT
From: Michael Fedak [mailto:mikefedak at gmail.com<mailto:mikefedak at gmail.com>]
Sent: Monday, October 22, 2018 3:20 PM
Cc: geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>; geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
 I had a similar issue on 2.8 last week. See here for the discussion/fix: https://github.com/GeoNode/geonode/issues/3984
On Mon, Oct 22, 2018 at 7:25 AM Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Dear Geonode community,
If someone knows little bit more about this, we would appreciate your help ☺ Explanation below:
We have installed Geonode on docker (version 2.10rc4). We imported first kml layer but updatelayers (from inside of django4geonode container) report problem "Could not ADD GeoServer User None Rule for Layer":
root at 5058e8a1637f:/usr/src/app# ./manage.py updatelayers
Found 1 layers, starting processing
  File "./manage.py", line 29, in <module>
    utility.execute()
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 283, in run_from_argv
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 330, in execute
  File "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line 124, in handle
  File "/usr/src/app/geonode/geoserver/helpers.py", line 637, in gs_slurp
  File "/usr/src/app/geonode/security/models.py", line 216, in set_permissions
  File "/usr/src/app/geonode/decorators.py", line 44, in wrapper
  File "/usr/src/app/geonode/security/utils.py", line 392, in sync_geofence_with_guardian
  File "/usr/src/app/geonode/security/utils.py", line 563, in _update_geofence_rule
Exception: ('Failed to process novi_r6_Slijepac_most_10kV', RuntimeError("Could not ADD GeoServer User None Rule for Layer u'novi_r6_Slijepac_most_10kV'",))
But the same command from celery4geonode container has different output:
root at bca672a5673d:/usr/src/app# ./manage.py updatelayers
/usr/local/lib/python2.7/site-packages/owslib/iso.py:117: FutureWarning: the .identification and .serviceidentification properties will merge into .identification being a list of properties.  This is currently implemented in .identificationinfo.  Please see https://github.com/geopython/OWSLib/issues/38 for more information
  FutureWarning)
/usr/local/lib/python2.7/site-packages/owslib/iso.py:482: FutureWarning: The .keywords and .keywords2 properties will merge into the .keywords property in the future, with .keywords becoming a list of MD_Keywords instances. This is currently implemented in .keywords2. Please see https://github.com/geopython/OWSLib/issues/301 for more information
  FutureWarning)
/usr/local/lib/python2.7/site-packages/geoserver/style.py:73: FutureWarning: The behavior of this method will change in future versions.  Use specific 'len(elem)' or 'elem is not None' test instead.
  if not user_style:
/usr/local/lib/python2.7/site-packages/geoserver/style.py:77: FutureWarning: The behavior of this method will change in future versions.  Use specific 'len(elem)' or 'elem is not None' test instead.
  if user_style:
... Creating Thumbnail for Layer [geonode:OPSTINE]
[updated] Layer OPSTINE (1/6)
... Creating Thumbnail for Layer [geonode:novi_novi_r6_Pavino_Polje_10kV_izmijenjen]
[updated] Layer novi_novi_r6_Pavino_Polje_10kV_izmijenjen (2/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Ambarine_Przista_10kV]
[created] Layer novi_r6_Ambarine_Przista_10kV (3/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Gimnazija_10_kV]
[updated] Layer novi_r6_Gimnazija_10_kV (4/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Planinica_10_kV]
[updated] Layer novi_r6_Planinica_10_kV (5/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Rasovo_10kV]
[updated] Layer novi_r6_Rasovo_10kV (6/6)
Finished processing 6 layers in 53.0 seconds.
1 Created layers
5 Updated layers
0 Failed layers
8.830000 seconds per layer
Is such behavior normal ?
Thanks in advance.
Kind regards,
Ana Boljević
Sektor za ICT
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181028/bb9375b6/attachment-0001.html>
More information about the geonode-users mailing list
