[GeoNode-users] Remove layer from GeoNode but keep in GeoServer
Daniel Victoria
daniel.victoria at gmail.com
Wed Sep 5 04:18:57 PDT 2018
Thanks, I'll check it out. But if the layer has already been added to
GeoNode by mistake, can it be 'de-listed'?
On Tue, Sep 4, 2018 at 2:21 PM Michael Fedak <mikefedak at gmail.com> wrote:
> Hello,
> Try switching the layers you do not want added to not be advertised. You
> can do this via the Edit Layer page in geoserver, there should be a 'Advertised''
> checkbox. Then run updatelayers with the --skip-unadvertised flag. See
> here for more details:
> http://docs.geonode.org/en/master/tutorials/admin/admin_mgmt_commands/index.html#updatelayers
> On Tue, Sep 4, 2018 at 12:43 PM Daniel Victoria <daniel.victoria at gmail.com>
> wrote:
>> Hi list,
>> Using GeoNode 2.8 installed from the Ubuntu ppa.
>> I manually added several layers in GeoServer and then I published them
>> using `geonode updatelayers` command. However, there are some layers in
>> GeoServer that I do not want to list in GeoNode.
>> If I delete the layer in GeoNode site, it will also be deleted in
>> GeoServer, right? How can I 'unlist' a layer from GeoNode and still keep it
>> in GeoServer?
>> Cheers
>> Daniel
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180905/fd1bcc9d/attachment.html>
More information about the geonode-users
