[GeoNode-users] Unable to start geoserver after installation.
Amedeo Fadini
amefad at gmail.com
Thu Sep 6 05:06:33 PDT 2018
Hi everybody,
I've installed geonode 2.8 on debian testing (buster) and started a geonode
project following the advices of the list and the project readme and
develoeprs workshop, and also this part of the guide
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
I was able to make it working on devlopment mode (port 8000 with django
webserver and jetty) but we need to setup also the production environment
so I went ahead installing apache and tomcat8...
1) installing tomcat 8.5.32 on testing didn't work with java 8, geoserver
didn't start.
2) installing tomcat 8.5.33 from binaries and geoserver 2.12 war geoserver
was working but I wasn't able to activate geonode authentication
3) in the meantime tomcat 8.5.333 was packed for debian buster but
geoserver doesn't start: here is the excerpt from catalina.out log with
error "one or more listeneres failed to start" there's no geoserver.log in
geoserver -logs dir.:
[2018-09-06 13:34:56] [info] Deploying web application archive
[/var/lib/tomcat8/webapps/geoserver.war]
[2018-09-06 13:35:01] [info] At least one JAR was scanned for TLDs yet
contained no TLDs. Enable debug logging for this logger for a complete list
of JARs that were scanned but no TLDs were found in them. Skipping unneeded
JARs during scanning can improve startup time and JSP compilation time.
[2018-09-06 13:35:02] [warning] Extension lookup
'XStreamPersisterInitializer', but ApplicationContext is unset.
[2018-09-06 13:35:03] [warning] Extension lookup
'GeoServerSecurityProvider', but ApplicationContext is unset.
[2018-09-06 13:35:03] [info] java.lang.UnsatisfiedLinkError: /tmp/
spatialite-3.7.22.4-libspatialitejdbc.so: libproj.so.0: cannot open shared
object file: No such file or directory
[2018-09-06 13:35:04] [info] java.lang.UnsatisfiedLinkError: /tmp/
[2018-09-06 13:35:04] [crit] One or more listeners failed to start. Full
details will be found in the appropriate container log file
[2018-09-06 13:35:04] [crit] Context [/geoserver] startup failed due to
previous errors
[2018-09-06 13:35:04] [info] Beginning GeoServer cleanup sequence
Any suggestion?
Amedeo Fadini
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180906/98879b47/attachment-0001.html>
More information about the geonode-users
