[GeoNode-users] Unable to start geoserver after installation.
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Sep 6 05:25:45 PDT 2018
Hi Amedeo,
are you using WARs from here http://build.geonode.org/geoserver/latest/ ?
Also, it would be possible to have a look at the full log? Possibly the
geoserver.log one. Listeners failed to start are a side effect of the
shutdown. The real cause should be somewhere else.
Il giorno gio 6 set 2018 alle ore 14:07 Amedeo Fadini <amefad at gmail.com> ha
scritto:
> Hi everybody,
> I've installed geonode 2.8 on debian testing (buster) and started a
> geonode project following the advices of the list and the project readme
> and develoeprs workshop, and also this part of the guide
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> I was able to make it working on devlopment mode (port 8000 with django
> webserver and jetty) but we need to setup also the production environment
> so I went ahead installing apache and tomcat8...
> 1) installing tomcat 8.5.32 on testing didn't work with java 8, geoserver
> didn't start.
> 2) installing tomcat 8.5.33 from binaries and geoserver 2.12 war geoserver
> was working but I wasn't able to activate geonode authentication
> 3) in the meantime tomcat 8.5.333 was packed for debian buster but
> geoserver doesn't start: here is the excerpt from catalina.out log with
> error "one or more listeneres failed to start" there's no geoserver.log in
> geoserver -logs dir.:
> [2018-09-06 13:34:56] [info] Deploying web application archive
> [/var/lib/tomcat8/webapps/geoserver.war]
> [2018-09-06 13:35:01] [info] At least one JAR was scanned for TLDs yet
> contained no TLDs. Enable debug logging for this logger for a complete list
> of JARs that were scanned but no TLDs were found in them. Skipping unneeded
> JARs during scanning can improve startup time and JSP compilation time.
> [2018-09-06 13:35:02] [warning] Extension lookup
> 'XStreamPersisterInitializer', but ApplicationContext is unset.
> [2018-09-06 13:35:03] [warning] Extension lookup
> 'GeoServerSecurityProvider', but ApplicationContext is unset.
> [2018-09-06 13:35:03] [info] java.lang.UnsatisfiedLinkError: /tmp/
> spatialite-3.7.22.4-libspatialitejdbc.so: libproj.so.0: cannot open
> shared object file: No such file or directory
> [2018-09-06 13:35:04] [info] java.lang.UnsatisfiedLinkError: /tmp/
> [2018-09-06 13:35:04] [crit] One or more listeners failed to start. Full
> details will be found in the appropriate container log file
> [2018-09-06 13:35:04] [crit] Context [/geoserver] startup failed due to
> previous errors
> [2018-09-06 13:35:04] [info] Beginning GeoServer cleanup sequence
> Any suggestion?
> Amedeo Fadini
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180906/7e697427/attachment.html>
More information about the geonode-users
