[GeoNode-users] Unable to start geoserver after installation.
Amedeo Fadini
amefad at gmail.com
Thu Sep 6 08:08:07 PDT 2018
Il giorno gio 6 set 2018 alle ore 16:51 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hello Amedeo,
> Thank you very much for your quik reply Alessio.
> That means that the user you are using to run Apache Tomcat does not have
> rights to write the GEOSERVER_DATA_DIR.
> Try to update the permissions and restart the web container.
Ok, I was already investigating about permission, I've forgot to change
owner of parent directory...
Now Geoserver 2.14 snapshot is working but still doesn't authenticat with
geofence... I see that the documentation tells to configure in
/data/geoserver-data/security/filter/geonode-oauth2/config.xml
but this file doesn't exists in 2.8 repo, i see
/data/geoserver-data/security/filter/geofence/config.xml
instead and I've tried to configure like this:
<geofence>
<id>-6c153d14:158ced62d5d:-7ff5</id>
<name>geofence</name>
<className>org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider</className>
<baseUrl>http://localhost/</baseUrl>
</geofence>
Amedeo
> Il giorno gio 6 set 2018 alle ore 16:46 Amedeo Fadini <amefad at gmail.com>
> ha scritto:
>> Il giorno gio 6 set 2018 alle ore 14:26 Alessio Fabiani <
>>> Hi Amedeo,
>>> are you using WARs from here http://build.geonode.org/geoserver/latest/
>> Yes, tested with 2.12, 2.13, 2.14
>>> Also, it would be possible to have a look at the full log? Possibly the
>>> geoserver.log one. Listeners failed to start are a side effect of the
>>> shutdown. The real cause should be somewhere else.
>>> I'm not able to find geoserver.log in any place of the filesystem...in
>> /etc/default/tomcat8 these options are loaded:
>> GEOSERVER_DATA_DIR="/home/geonode/data/geoserver-data"
>> GEOSERVER_LOG_LOCATION="/home/geonode/data/geoserver-logs/geoserver.log"
>> GEOWEBCACHE_CACHE_DIR="/home/geonode/data/gwc_cache_dir"
>> GEOFENCE_DIR="$GEOSERVER_DATA_DIR/geofence"
>> UPDATE: I've just realized that wrong path were specified in
>> $GEOSERVER_DATA_DIR/logging.xml : FIXED
>> Attached full catalina.out and geoserver.log (I see a UTC time in
>> goserver log and local time in catalina.out.. mumble..)
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180906/1dafb194/attachment-0001.html>
More information about the geonode-users
