[GeoNode-users] Unable to start geoserver after installation.
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Sep 6 08:10:18 PDT 2018
Hi Amedeo,
do not use 2.14 yet, the REST paths of GeoFence have been changed since
2.13.
Use 2.13 instead.
Il giorno gio 6 set 2018 alle ore 17:08 Amedeo Fadini <amefad at gmail.com> ha
scritto:
> Il giorno gio 6 set 2018 alle ore 16:51 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Hello Amedeo,
>> Thank you very much for your quik reply Alessio.
>> That means that the user you are using to run Apache Tomcat does not have
>> rights to write the GEOSERVER_DATA_DIR.
>> Try to update the permissions and restart the web container.
> Ok, I was already investigating about permission, I've forgot to change
> owner of parent directory...
> Now Geoserver 2.14 snapshot is working but still doesn't authenticat with
> geofence... I see that the documentation tells to configure in
> /data/geoserver-data/security/filter/geonode-oauth2/config.xml
> but this file doesn't exists in 2.8 repo, i see
> /data/geoserver-data/security/filter/geofence/config.xml
> instead and I've tried to configure like this:
> <geofence>
> <id>-6c153d14:158ced62d5d:-7ff5</id>
> <name>geofence</name>
> <className>org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider</className>
> <baseUrl>http://localhost/</baseUrl>
> </geofence>
> Amedeo
>> Il giorno gio 6 set 2018 alle ore 16:46 Amedeo Fadini <amefad at gmail.com>
>> ha scritto:
>>> Il giorno gio 6 set 2018 alle ore 14:26 Alessio Fabiani <
>>>> Hi Amedeo,
>>>> are you using WARs from here http://build.geonode.org/geoserver/latest/
>>> Yes, tested with 2.12, 2.13, 2.14
>>>> Also, it would be possible to have a look at the full log? Possibly the
>>>> geoserver.log one. Listeners failed to start are a side effect of the
>>>> shutdown. The real cause should be somewhere else.
>>>> I'm not able to find geoserver.log in any place of the filesystem...in
>>> /etc/default/tomcat8 these options are loaded:
>>> GEOSERVER_DATA_DIR="/home/geonode/data/geoserver-data"
>>> GEOSERVER_LOG_LOCATION="/home/geonode/data/geoserver-logs/geoserver.log"
>>> GEOWEBCACHE_CACHE_DIR="/home/geonode/data/gwc_cache_dir"
>>> GEOFENCE_DIR="$GEOSERVER_DATA_DIR/geofence"
>>> UPDATE: I've just realized that wrong path were specified in
>>> $GEOSERVER_DATA_DIR/logging.xml : FIXED
>>> Attached full catalina.out and geoserver.log (I see a UTC time in
>>> goserver log and local time in catalina.out.. mumble..)
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180906/ede78e42/attachment-0001.html>
More information about the geonode-users
