[GeoNode-users] Unable to start geoserver after installation.
    Amedeo Fadini
    amefad at gmail.com
    Thu Sep  6 16:13:23 PDT 2018
Ok restored 2.12.2 and is working,
I forgot to check the correct uris in
$GEOSERVER_DATA_DIR/security/filter/config.xml
changed from localhost:8000 to localhost
Solved, Thank-you very much
I suggest to remove from documentation [0] step 3 as
$GEOSERVER_DATA_DIR/security/auth/geonodeAuthProvider folder is not present
in 2.8.x
I made a pull request
Amefad
[0]
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration
Il giorno gio 6 set 2018 alle ore 17:10 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hi Amedeo,
> do not use 2.14 yet, the REST paths of GeoFence have been changed since
> 2.13.
> Use 2.13 instead.
> Il giorno gio 6 set 2018 alle ore 17:08 Amedeo Fadini <amefad at gmail.com>
> ha scritto:
>> Il giorno gio 6 set 2018 alle ore 16:51 Alessio Fabiani <
>>> Hello Amedeo,
>>> Thank you very much for your quik reply Alessio.
>>> That means that the user you are using to run Apache Tomcat does not
>>> have rights to write the GEOSERVER_DATA_DIR.
>>> Try to update the permissions and restart the web container.
>>  Ok, I was already investigating about permission, I've forgot to change
>> owner of parent directory...
>> Now Geoserver 2.14 snapshot is working but still doesn't authenticat with
>> geofence... I see that the documentation tells to configure in
>> /data/geoserver-data/security/filter/geonode-oauth2/config.xml
>>  but this file doesn't exists in 2.8 repo,  i see
>> /data/geoserver-data/security/filter/geofence/config.xml
>> instead and I've tried to configure like this:
>> <geofence>
>>   <id>-6c153d14:158ced62d5d:-7ff5</id>
>>   <name>geofence</name>
>> <className>org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider</className>
>>   <baseUrl>http://localhost/</baseUrl>
>> </geofence>
>> Amedeo
>>> Il giorno gio 6 set 2018 alle ore 16:46 Amedeo Fadini <amefad at gmail.com>
>>> ha scritto:
>>>> Il giorno gio 6 set 2018 alle ore 14:26 Alessio Fabiani <
>>>>> Hi Amedeo,
>>>>> are you using WARs from here
>>>>> http://build.geonode.org/geoserver/latest/ ?
>>>> Yes, tested with 2.12, 2.13, 2.14
>>>>> Also, it would be possible to have a look at the full log? Possibly
>>>>> the geoserver.log one. Listeners failed to start are a side effect of the
>>>>> shutdown. The real cause should be somewhere else.
>>>>> I'm not able to find geoserver.log in any place of the filesystem...in
>>>> /etc/default/tomcat8 these options are loaded:
>>>> GEOSERVER_DATA_DIR="/home/geonode/data/geoserver-data"
>>>> GEOSERVER_LOG_LOCATION="/home/geonode/data/geoserver-logs/geoserver.log"
>>>> GEOWEBCACHE_CACHE_DIR="/home/geonode/data/gwc_cache_dir"
>>>> GEOFENCE_DIR="$GEOSERVER_DATA_DIR/geofence"
>>>> UPDATE: I've just realized that wrong path were specified in
>>>> $GEOSERVER_DATA_DIR/logging.xml : FIXED
>>>> Attached full catalina.out and geoserver.log (I see a UTC time in
>>>> goserver log and local time in catalina.out.. mumble..)
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180907/dd54404d/attachment-0001.html>
More information about the geonode-users
