[GeoNode-users] Unable to start geoserver after installation.
francesco bartoli xbartolone at gmail.com
Thu Sep 6 22:49:54 PDT 2018
Thanks Amedeo, merged.
Il giorno ven 7 set 2018 alle ore 01:14 Amedeo Fadini <amefad at gmail.com> ha
scritto:
> Ok restored 2.12.2 and is working,
> I forgot to check the correct uris in
> $GEOSERVER_DATA_DIR/security/filter/config.xml
> changed from localhost:8000 to localhost
> Solved, Thank-you very much
> I suggest to remove from documentation [0] step 3 as
> $GEOSERVER_DATA_DIR/security/auth/geonodeAuthProvider folder is not present
> in 2.8.x
> I made a pull request
> Amefad
> [0]
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration
> Il giorno gio 6 set 2018 alle ore 17:10 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Hi Amedeo,
>> do not use 2.14 yet, the REST paths of GeoFence have been changed since
>> 2.13.
>> Use 2.13 instead.
>> Il giorno gio 6 set 2018 alle ore 17:08 Amedeo Fadini <amefad at gmail.com>
>> ha scritto:
>>> Il giorno gio 6 set 2018 alle ore 16:51 Alessio Fabiani <
>>>> Hello Amedeo,
>>>> Thank you very much for your quik reply Alessio.
>>>> That means that the user you are using to run Apache Tomcat does not
>>>> have rights to write the GEOSERVER_DATA_DIR.
>>>> Try to update the permissions and restart the web container.
>>>  Ok, I was already investigating about permission, I've forgot to change
>>> owner of parent directory...
>>> Now Geoserver 2.14 snapshot is working but still doesn't authenticat
>>> with geofence... I see that the documentation tells to configure in
>>> /data/geoserver-data/security/filter/geonode-oauth2/config.xml
>>>  but this file doesn't exists in 2.8 repo,  i see
>>> /data/geoserver-data/security/filter/geofence/config.xml
>>> instead and I've tried to configure like this:
>>> <geofence>
>>>   <id>-6c153d14:158ced62d5d:-7ff5</id>
>>>   <name>geofence</name>
>>> <className>org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider</className>
>>>   <baseUrl>http://localhost/</baseUrl>
>>> </geofence>
>>> Amedeo
>>>> Il giorno gio 6 set 2018 alle ore 16:46 Amedeo Fadini <amefad at gmail.com>
>>>> ha scritto:
>>>>> Il giorno gio 6 set 2018 alle ore 14:26 Alessio Fabiani <
>>>>>> Hi Amedeo,
>>>>>> are you using WARs from here
>>>>>> http://build.geonode.org/geoserver/latest/ ?
>>>>> Yes, tested with 2.12, 2.13, 2.14
>>>>>> Also, it would be possible to have a look at the full log? Possibly
>>>>>> the geoserver.log one. Listeners failed to start are a side effect of the
>>>>>> shutdown. The real cause should be somewhere else.
>>>>>> I'm not able to find geoserver.log in any place of the
>>>>> filesystem...in /etc/default/tomcat8 these options are loaded:
>>>>> GEOSERVER_DATA_DIR="/home/geonode/data/geoserver-data"
>>>>> GEOSERVER_LOG_LOCATION="/home/geonode/data/geoserver-logs/geoserver.log"
>>>>> GEOWEBCACHE_CACHE_DIR="/home/geonode/data/gwc_cache_dir"
>>>>> GEOFENCE_DIR="$GEOSERVER_DATA_DIR/geofence"
>>>>> UPDATE: I've just realized that wrong path were specified in
>>>>> $GEOSERVER_DATA_DIR/logging.xml : FIXED
>>>>> Attached full catalina.out and geoserver.log (I see a UTC time in
>>>>> goserver log and local time in catalina.out.. mumble..)
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180907/64cd6ac4/attachment-0001.html>
More information about the geonode-users mailing list
