[GeoNode-users] GeoNode 2.8 Add remote service error
Simone Dalmasso simone.dalmasso at gmail.com
Fri Sep 14 06:44:38 PDT 2018
Hi Matteo, could you please post the url you are trying to add?
Il giorno ven 14 set 2018 alle ore 07:34 Matteo Conte <
matteo.conte at abitat.it> ha scritto:
> Hi all,
> when I try to add a remote service I get this result. I tried several WMS
> services but nothing changes
> [image: geonode_3]
> <https://user-images.githubusercontent.com/958331/45446264-bae5b500-b6cc-11e8-9053-410045d1c82e.JPG>
> In the apache log I find this error
> extern "Python": function Cryptography_rand_bytes() called, but
> @ffi.def_extern() was not called i[Wed Sep 12 13:46:30.111888 2018]
> [wsgi:error] [pid 10169:tid 140123747006208] Internal Server Error:
> /services/register/
> [Wed Sep 12 13:46:30.111953 2018] [wsgi:error] [pid 10169:tid
> 140123747006208] Traceback (most recent call last):
> [Wed Sep 12 13:46:30.111959 2018] [wsgi:error] [pid 10169:tid
> 140123747006208] File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 132,
> in get_response
> [Wed Sep 12 13:46:30.111964 2018] [wsgi:error] [pid 10169:tid
> 140123747006208] response = wrapped_callback(request, *callback_args,
> **callback_kwargs)
> [Wed Sep 12 13:46:30.111968 2018] [wsgi:error] [pid 10169:tid
> "/usr/lib/python2.7/dist-packages/django/contrib/auth/decorators.py", line
> 22, in _wrapped_view
> [Wed Sep 12 13:46:30.111972 2018] [wsgi:error] [pid 10169:tid
> 140123747006208] return view_func(request, *args, **kwargs)
> [Wed Sep 12 13:46:30.111975 2018] [wsgi:error] [pid 10169:tid
> "/usr/local/lib/python2.7/dist-packages/geonode/services/views.py", line
> 86, in register_service
> [Wed Sep 12 13:46:30.111979 2018] [wsgi:error] [pid 10169:tid
> 140123747006208] service.full_clean()
> [Wed Sep 12 13:46:30.111983 2018] [wsgi:error] [pid 10169:tid
> "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 1171, in
> full_clean
> [Wed Sep 12 13:46:30.111986 2018] [wsgi:error] [pid 10169:tid
> 140123747006208] raise ValidationError(errors)
> [Wed Sep 12 13:46:30.111990 2018] [wsgi:error] [pid 10169:tid
> 140123747006208] ValidationError: {'proxy_base': [u'Inserisci un URL
> valido.']}
> If I try the service url on QGIS it work fine
> Can you help me?
> Best regards
> Matteo
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180914/6b610423/attachment.html>
More information about the geonode-users mailing list
