[GeoNode-users] GeoNode Project master Docker - Upload layers
Simone Dalmasso
simone.dalmasso at gmail.com
Sat Sep 15 01:17:58 PDT 2018
which version of GeoNode are you using. Keep in mind that the
geonode-project branch you use should follow the geonode's version.
Best
Il giorno ven 14 set 2018 alle ore 22:37 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear users,
> I had geonode-project at 2.7 running perfectly fine, including uploading
> layers. Now, I am running GeoNode-Project at master, but I am unable to
> upload data layers. The following message is shown at the end of the
> uploading layers process:
> *Unable to
> usecom.vividsolutions.jts.geom.impl.CoordinateArraySequenceFactory at 32f58c5e
> to produce CoordinateSequence with dimension 2*
> This would not happen on version 2.7
> Any comment on this issue would be very appreciated.
> Kind regards
> Julierme
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180915/47fc89d7/attachment.html>
More information about the geonode-users
