[GeoNode-users] Zoom to layer extend does not work
Paulo Frias
pfrias82 at gmail.com
Sun Sep 16 03:27:43 PDT 2018
Hi all,
This issue didn't worked for me
https://github.com/GeoNode/geonode/pull/3732/files.
I start to be very disappointed with GeoNode. I think unless you are a very
good programmer you can't do too much with it.
I installed Geonode on Ubuntu 16.04 and 18.04, on Windows and I also tried
in a Virtual env on Mac OS X. The quick start installation works on Windows
but on Ubuntu when I upload de layer and then try to watch them the zoom
goes to different places on earth and never to layer. I even format both my
ubuntu machine and windows machine to check if it was not some conflict
with other python versions installed. The same happens when I reinstall it.
I also try to install step by step as described on GeoNode website but I
have the same issues.
I think it's very odd that I'm the only one with this kind of problems. The
stable version should work fine to a nom programmer like myself.
I don't know what to do more to solve this issue and in fact use GeoNode.
On Fri, 14 Sep 2018 at 18:53, Elton Davis Turin Espinoza <eturine at uni.pe>
wrote:
> Hi all,
> The question is where would I put the this code for all the layers.
> var bBox = new OpenLayers.Bounds(
> 68.14806781208101, 20.118149140613397,
> 74.47891169978561, 24.722655175866358
> map.zoomToExtent(bBox);
> Regards,
> Elton
> 2018-09-13 19:48 GMT-05:00 Elton Davis Turin Espinoza <eturine at uni.pe>:
>> Hi all, i have the same problem and dont can solve.
>> please can you tell me where to put the center of the map in hard for tha
>> layer.
>> It is a quick solution for me.
>> Thank you a lot.
>> Elton
>> 2018-09-05 14:07 GMT-05:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de
>>> Dear Paulo,
>>> this sounds much like:
>>> Cheers,
>>> Toni
>>> CSGIS
>>> Kolonnadenstraße 1
>>> 04109 Leipzig
>>> Mobil +49/ (0) 176 6680 3198
>>> Tel +49/ (0) 341 24 04 738
>>> Fax +49/ (0) 341 24 04 73
>>> Web http://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> Am 05.09.2018 um 21:00 schrieb geonode-users-request at lists.osgeo.org:
>>> Message: 1
>>> Date: Wed, 5 Sep 2018 16:21:14 +0100
>>> From: Paulo Frias <pfrias82 at gmail.com>
>>> To: geonode-users at lists.osgeo.org
>>> Subject: [GeoNode-users] Zoom to layer extend does not work
>>> Message-ID:
>>> <CA+PD0U1LsPwHohAMuSnd0sRwFsr6PwCmmdRdxtq-CMCaXTOsvA at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi everyone,
>>> I'm running Geonode 2.8 on Ubuntu 16.04.
>>> When I choose to visualize one of the imported layers they never zoom to
>>> the layer itself. This error was supposedly fixed and I've checked the
>>> files to see if everything was correct.
>>> I've also installed Geonode on a Windows machine and the same layers
>>> there
>>> appear zoomed to layer extend.
>>> Is there someone who knows one solution for this problem?
>>> Thanks,
>>> Paulo
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> "Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
> entidad que se muestra como destinatario/s y pueden contener datos
> personales y/o información confidencial, sometida a secreto profesional o
> cuya divulgación esté prohibida en la legislación vigente. Que
> <http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación, reproducción
> u otra acción al respecto por parte de personas o entidades distintas al
> destinatario/s. Si ha recibido este mensaje por error, por favor,
> contáctenos a la siguiente dirección de correo electrónico lpdp at uni.edu.pe
> y proceda a su eliminación.
> En cumplimiento a lo establecido en la Ley de Protección de Datos
> Personales - Ley N° 29733, le informamos que sus datos personales obtenidos
> son almacenados bajo la confidencialidad y las medidas de seguridad
> legalmente establecidas y no serán cedidos ni compartidos con empresas ni
> entidades ajenas a la Universidad Nacional de Ingeniería. Si lo desea,
> usted podrá ejercitar los derechos de actualización,
> inclusión, rectificación, supresión u oposición, enviando un mensaje al
> correo electrónico anteriormente señalado e indicando en el "Asunto" el
> derecho que desea ejercer"
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180916/ebd650f0/attachment-0001.html>
More information about the geonode-users
