[GeoNode-users] Zoom to layer extend does not work
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Sep 17 01:38:57 PDT 2018
There are professional services that might help you fix your issues quickly
if you don't have the patient to wait the standard behavior of an open
source project.
In any case, I strongly suggest to always being aligned with the latest
versions. To install them you need at least a system administrator or a
devop.
Il giorno dom 16 set 2018 alle ore 12:27 Paulo Frias <pfrias82 at gmail.com>
ha scritto:
> Hi all,
> This issue didn't worked for me
> https://github.com/GeoNode/geonode/pull/3732/files.
> I start to be very disappointed with GeoNode. I think unless you are a
> very good programmer you can't do too much with it.
> I installed Geonode on Ubuntu 16.04 and 18.04, on Windows and I also tried
> in a Virtual env on Mac OS X. The quick start installation works on Windows
> but on Ubuntu when I upload de layer and then try to watch them the zoom
> goes to different places on earth and never to layer. I even format both my
> ubuntu machine and windows machine to check if it was not some conflict
> with other python versions installed. The same happens when I reinstall it.
> I also try to install step by step as described on GeoNode website but I
> have the same issues.
> I think it's very odd that I'm the only one with this kind of problems.
> The stable version should work fine to a nom programmer like myself.
> I don't know what to do more to solve this issue and in fact use GeoNode.
> On Fri, 14 Sep 2018 at 18:53, Elton Davis Turin Espinoza <eturine at uni.pe>
> wrote:
>> Hi all,
>> The question is where would I put the this code for all the layers.
>> var bBox = new OpenLayers.Bounds(
>> 68.14806781208101, 20.118149140613397,
>> 74.47891169978561, 24.722655175866358
>> map.zoomToExtent(bBox);
>> Regards,
>> Elton
>> 2018-09-13 19:48 GMT-05:00 Elton Davis Turin Espinoza <eturine at uni.pe>:
>>> Hi all, i have the same problem and dont can solve.
>>> please can you tell me where to put the center of the map in hard for
>>> tha layer.
>>> It is a quick solution for me.
>>> Thank you a lot.
>>> Elton
>>> 2018-09-05 14:07 GMT-05:00 Toni Schönbuchner <
>>> toni.schoenbuchner at csgis.de>:
>>>> Dear Paulo,
>>>> this sounds much like:
>>>> Cheers,
>>>> Toni
>>>> CSGIS
>>>> Kolonnadenstraße 1
>>>> 04109 Leipzig
>>>> Mobil +49/ (0) 176 6680 3198
>>>> Tel +49/ (0) 341 24 04 738
>>>> Fax +49/ (0) 341 24 04 73
>>>> Web http://csgis.de
>>>> Hinweis gemäß § 33 BDSG
>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>>> ausschließlich für den
>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>> diese E-Mail versehentlich
>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>> löschen Sie diese Nachricht
>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>> Vervielfältigung, Veränderung,
>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>> Am 05.09.2018 um 21:00 schrieb geonode-users-request at lists.osgeo.org:
>>>> Message: 1
>>>> Date: Wed, 5 Sep 2018 16:21:14 +0100
>>>> From: Paulo Frias <pfrias82 at gmail.com>
>>>> To: geonode-users at lists.osgeo.org
>>>> Subject: [GeoNode-users] Zoom to layer extend does not work
>>>> Message-ID:
>>>> <CA+PD0U1LsPwHohAMuSnd0sRwFsr6PwCmmdRdxtq-CMCaXTOsvA at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Hi everyone,
>>>> I'm running Geonode 2.8 on Ubuntu 16.04.
>>>> When I choose to visualize one of the imported layers they never zoom to
>>>> the layer itself. This error was supposedly fixed and I've checked the
>>>> files to see if everything was correct.
>>>> I've also installed Geonode on a Windows machine and the same layers
>>>> there
>>>> appear zoomed to layer extend.
>>>> Is there someone who knows one solution for this problem?
>>>> Thanks,
>>>> Paulo
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> "Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
>> entidad que se muestra como destinatario/s y pueden contener datos
>> personales y/o información confidencial, sometida a secreto profesional o
>> cuya divulgación esté prohibida en la legislación vigente. Que
>> <http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación,
>> reproducción u otra acción al respecto por parte de personas o entidades
>> distintas al destinatario/s. Si ha recibido este mensaje por error, por
>> favor, contáctenos a la siguiente dirección de correo electrónico
>> lpdp at uni.edu.pe y proceda a su eliminación.
>> En cumplimiento a lo establecido en la Ley de Protección de Datos
>> Personales - Ley N° 29733, le informamos que sus datos personales obtenidos
>> son almacenados bajo la confidencialidad y las medidas de seguridad
>> legalmente establecidas y no serán cedidos ni compartidos con empresas ni
>> entidades ajenas a la Universidad Nacional de Ingeniería. Si lo desea,
>> usted podrá ejercitar los derechos de actualización,
>> inclusión, rectificación, supresión u oposición, enviando un mensaje al
>> correo electrónico anteriormente señalado e indicando en el "Asunto" el
>> derecho que desea ejercer"
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180917/4b443c1d/attachment-0001.html>
More information about the geonode-users
