[GeoNode-users] GeoNode Backup Error
Ramirez, Gabriel Gabriel.Ramirez at ventura.org
Mon Sep 24 10:34:53 PDT 2018
I keep getting the follow error message when running sudo geonode backup -backup-dir /opt/backups
Any idea on how to fix it?
Before proceeding with the Backup, please ensure that:
1. The backend (DB or whatever) is accessible and you have rights
2. The GeoServer is up and running and reachable from this machine
You want to proceed? [n]|y: y
Dumping 'GeoServer Catalog [http://18.210.188.238/geoserver/]' into '/opt/backups/2018-09-24_123215/geoserver_catalog.zip'.
STARTED - 1/11
STARTED - 7/11
COMPLETED - 11/11
  File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py", line 302, in copy_tree
    for item in os.listdir(src):
OSError: [Errno 2] No such file or directory: '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'
Dumped GeoServer Uploaded Data from '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'.
Dumping GeoServer Vectorial Data : noaa100yr24hrcontour0pt5nad83clip
Dumping GeoServer Vectorial Data : redline
Dumping GeoServer Vectorial Data : noaa_50yr24hr0pt5contournad83clip
Dumping GeoServer Vectorial Data : noaa25yr24hrcontoursclip
Dumping GeoServer Vectorial Data : facilitesbyreach
Dumping GeoServer Vectorial Data : lidar_index_1
Dumping GeoServer Vectorial Data : noaa10yr24hrcontours83clip
Dumping GeoServer Vectorial Data : noaarainzonescondensednad83_6_2017
Dumping GeoServer Vectorial Data : mr_records
Duming geoserver external resources
Deactivating GeoNode Signals...
...done!
Dumping 'contenttypes' into 'contenttypes.json'.
Dumping 'auth' into 'auth.json'.
Dumping 'people' into 'people.json'.
Dumping 'groups' into 'groups.json'.
Dumping 'account' into 'account.json'.
Dumping 'actstream' into 'actstream.json'.
Dumping 'admin' into 'admin.json'.
Dumping 'agon_ratings' into 'agon_ratings.json'.
Dumping 'announcements' into 'announcements.json'.
Dumping 'avatar' into 'avatar.json'.
Dumping 'base' into 'base.json'.
Dumping 'content' into 'content.json'.
Reactivating GeoNode Signals...
...done!
CommandError: Unknown application: content
ubuntu at ip-10-0-56-12:/opt/backups$
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180924/627fe38b/attachment.html>
More information about the geonode-users mailing list
