[GeoNode-users] GeoNode Backup Error
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Sep 25 06:58:20 PDT 2018
You need to correctly configure your "settings.ini" as explained here
http://docs.geonode.org/en/master/tutorials/admin/backup_restore/#settings
If you still have issues on this, please open an issue on the
https://github.com/GeoNode/geonode/issues repository so we can track it.
Il giorno lun 24 set 2018 alle ore 19:44 Ramirez, Gabriel <
Gabriel.Ramirez at ventura.org> ha scritto:
> I keep getting the follow error message when running sudo geonode backup
> –backup-dir /opt/backups
> Any idea on how to fix it?
> Before proceeding with the Backup, please ensure that:
> 1. The backend (DB or whatever) is accessible and you have rights
> 2. The GeoServer is up and running and reachable from this machine
> You want to proceed? [n]|y: y
> Dumping 'GeoServer Catalog [http://18.210.188.238/geoserver/]' into
> '/opt/backups/2018-09-24_123215/geoserver_catalog.zip'.
> STARTED - 1/11
> STARTED - 7/11
> COMPLETED - 11/11
> Traceback (most recent call last):
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
> line 302, in copy_tree
>     for item in os.listdir(src):
> OSError: [Errno 2] No such file or directory:
> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'
> Dumped GeoServer Uploaded Data from
> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'.
> Dumping GeoServer Vectorial Data : noaa100yr24hrcontour0pt5nad83clip
> Dumping GeoServer Vectorial Data : redline
> Dumping GeoServer Vectorial Data : noaa_50yr24hr0pt5contournad83clip
> Dumping GeoServer Vectorial Data : noaa25yr24hrcontoursclip
> Dumping GeoServer Vectorial Data : facilitesbyreach
> Dumping GeoServer Vectorial Data : lidar_index_1
> Dumping GeoServer Vectorial Data : noaa10yr24hrcontours83clip
> Dumping GeoServer Vectorial Data : noaarainzonescondensednad83_6_2017
> Dumping GeoServer Vectorial Data : mr_records
> Duming geoserver external resources
> Deactivating GeoNode Signals...
> ...done!
> Dumping 'contenttypes' into 'contenttypes.json'.
> Dumping 'auth' into 'auth.json'.
> Dumping 'people' into 'people.json'.
> Dumping 'groups' into 'groups.json'.
> Dumping 'account' into 'account.json'.
> Dumping 'actstream' into 'actstream.json'.
> Dumping 'admin' into 'admin.json'.
> Dumping 'agon_ratings' into 'agon_ratings.json'.
> Dumping 'announcements' into 'announcements.json'.
> Dumping 'avatar' into 'avatar.json'.
> Dumping 'base' into 'base.json'.
> Dumping 'content' into 'content.json'.
> Reactivating GeoNode Signals...
> ...done!
> CommandError: Unknown application: content
> ubuntu at ip-10-0-56-12:/opt/backups$
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180925/a9a2453b/attachment.html>
More information about the geonode-users mailing list
