[GeoNode-users] Uploading Shapefile(Polygon features) - Displaying as Point in GeoNode Map/layer View
Naresh N
naresh919 at gmail.com
Mon Apr 15 02:54:49 PDT 2019
Dear All,
kindly help to resolve the *issue* '*Uploading Shapefile of type
polygon/line in GeoNode 2.4 showing as Point Layer in Map/ Viewer section'*
*Please answer my following doubts and hep to resolve the issue*
1. Is GeoNode 2.4 compatible with PostgreSQL 10.7 and PostGIS 2.5.2
2. Uploaded Shapefile of type Polygon in PostgreSQL Database table showing*
the_geom attribute data type* as as Geometry (PgAdmin4). and even in
GeoServer Layer interface 'the_geom' attribute data type showing as
Geometry. How to correct ' the{_geom' attribute data type based on features
type in Shapefile . Which part of the code in GeoNode verifies and assigns
the attribute type of Shapefile.
Kindly help me to fix the issue and please let me know any other
information required.
Thanks&Regards,
Naresh.N
On Wed, Apr 10, 2019 at 2:35 PM Naresh N <naresh919 at gmail.com> wrote:
> Dear Simone,
> Please kindly see the trailing mail and help me to solve the issue. I have
> already posted in GeoNode discussion forum, not able to solve the isssue.
> Kindly help in this regard.
> Thanks&Regards,
> Naresh
> ---------- Forwarded message ---------
> From: Naresh N <naresh919 at gmail.com>
> Date: Mon, Apr 8, 2019 at 4:58 PM
> Subject: Uploading Shapefile(Polygon features) - Displaying as Point in
> To: geonode-users lists.osgeo.org <geonode-users at lists.osgeo.org>,
> Alessio Fabiani <alessio.fabiani at geo-solutions.it>, Simone Dalmasso <
> simone.dalmasso at gmail.com>
> Dear All,
> I have deployed the GeoNode 2.4 version by following the instructions
> http://docs.geonode.org/en/2.4.x/tutorials/install_and_admin/setup_on_centos/index.html
> *ISSUE : *When I am uploading shapefile(polygon), it is taking the
> default point SLD. Hence when I am viewing the Uploaded Shapfeil(polygon)
> as WMS in Map/Layer View , it is displaying as point.
> *Kindly help me to resolve this issue. *
> GeoNode Deployed system configuration are
> *OS:*RHEL 7.2, 64 bit , GeoNode2.4 version
> Please let me know any other information required further to understand
> the issue.
> Thanks&Regards,
> Naresh.N
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190415/374ae2d4/attachment-0001.html>
More information about the geonode-users
