[GeoNode-users] Uploading Shapefile(Polygon features) - Displaying as Point in GeoNode Map/layer View
Jose Cáceres jose.atyus at gmail.com
Tue Apr 9 11:00:17 PDT 2019
Hi Naresh,
Just a followed up on my previous email, you need to be logged in, in order
to edit a feature layer.
Kind regards,
José
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
09/04/19
11:59:24
On Tue, Apr 9, 2019 at 11:51 AM Jose Cáceres <jose.atyus at gmail.com> wrote:
> Hi Naresh,
> As mentioned by Julierme, you feature is a polygon, and I can edit it just
> fine in a Geonode deploy, so I don't think that the problem you are having
> is related to the shapefile. You can see it on a map in here:
> http://206.189.229.38/maps/189/view
> Kind regards,
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 09/04/19
> 11:49:16
> On Tue, Apr 9, 2019 at 4:34 AM Naresh N <naresh919 at gmail.com> wrote:
>> Hello All,
>> Thanks for responding. Please find the attached Shapefile of polygon.
>> After Uploading any shapfiile of type polygon/line, in GeoNode Map/Layer
>> viewer, only point is visible. I have verified the code/db, the issue is
>> point SLD is applied for uploaded data independent of feature type . And
>> also in Layer/Map Viewer ---> EDIT --> *CREATE option* is *disabled.*
>> Please kindly help us in GeoNode which part of code/file verifies
>> feature/Geometry type(Polygon/lIne/point) of Shapefile and assigns
>> corresponding default SLD
>> Kindly help us to resolve the issues
>> Thanks&Regards,
>> Naresh.N
>> On Tue, Apr 9, 2019 at 2:58 AM juliermeopensourcedeveloper [via
>> OSGeo.org] <ml+s1560n5401239h2 at n6.nabble.com> wrote:
>>> Hi Naresh,
>>> Could you provide the shapefile you are having problem?
>>> Kind regards
>>> Julierme
>>> On Mon, 8 Apr 2019 at 08:28 Naresh N <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5401239&i=0>> wrote:
>>>> Dear All,
>>>> I have deployed the GeoNode 2.4 version by following  the instructions
>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_and_admin/setup_on_centos/index.html
>>>> *ISSUE : *When I am uploading shapefile(polygon), it is taking the
>>>> default point SLD. Hence when I am viewing the Uploaded Shapfeil(polygon)
>>>> as WMS in Map/Layer View , it is displaying as point.
>>>> *Kindly help me to resolve this issue. *
>>>> GeoNode Deployed system configuration are
>>>> *OS:*RHEL 7.2, 64 bit , GeoNode2.4 version
>>>> Please let me know any other information required further to understand
>>>> the issue.
>>>> Thanks&Regards,
>>>> Naresh.N
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5401239&i=1>
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> geonode-devel mailing list
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5401239&i=2>
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> http://osgeo-org.1560.x6.nabble.com/Re-GeoNode-users-Uploading-Shapefile-Polygon-features-Displaying-as-Point-in-GeoNode-Map-layer-View-tp5401239.html
>>> To unsubscribe from GeoNode, click here
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185390&code=bmFyZXNoOTE5QGdtYWlsLmNvbXw1MTg1MzkwfC0xMDc3NTYzNDE5>
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> geonode-users at lists.osgeo.org
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
José David Cáceres
Ingeniero Ambiental
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190409/329defd6/attachment-0001.html>
More information about the geonode-users mailing list
