[GeoNode-users] [Can't communicate with GeoServer: port 8000 vs 8080][Geonode 2.10 in Development Mode]
Tomas Link
tomaslink at spacesur.com
Tue Apr 16 14:42:13 PDT 2019
In the master branch, that option *GEOSERVER_PUBLIC_PORT *does exists and
solves the issue.
El mar., 16 abr. 2019 a las 21:16, Tomas Link (<tomaslink at spacesur.com>)
escribió:
> Hi Julierme,
> Thanks for the reply.
> I'm using this guide, more or less:
> http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html#ubuntu-for-development
> In Ubuntu 16.04 and the tag from 2.10rc4.
> I had to make a couple of changes to make work the *paver setup* command.
> But I successfully started GeoNode after that.
> GeoServer is wroking well also, in port 8080.
> I don't have the variable* GEOSERVER_PUBLIC_PORT* declared in my
> settings.py.
> I tried add that one in the settings.py as you suggested but the problem
> is still there.
> I debbuged the code in *geonode/proxy/views.py*, in the "proxy" function
> and what I can see is that, for every request, redirects to *host*:*port*{
> *locator*} where *locator* = '/geoserver/' in this case, and *host* and
> *port* are the the ones from GeoNode. The request parameter holds
> correctly the *host:8080/geoserver* URL, but this code always redirects
> to the same host and port of GeoNode.
> I don't had this problem when I deployed 2.8 for production, because
> Apache Server redirects geoserver requests to port 8080 correctly. But in
> this development environment, I don't know how we must handle that.
> El mar., 16 abr. 2019 a las 17:41, 1520 gis (<
> juliermeopensourcedeveloper at gmail.com>) escribió:
>> Hi Tomas,
>> What GeoNode installation method are you using?
>> In your local_settings.py, see if this change can help you:
>> *# **C**omment the line**s*#GEOSERVER_PUBLIC_PORT = os.getenv(# 'GEOSERVER_PUBLIC_PORT', *SITE_HOST_PORT*#)*# Add the lines*GEOSERVER_PUBLIC_PORT = os.getenv( 'GEOSERVER_PUBLIC_PORT', '*8080*')
>> I hope it helps
>> Julierme
>> On Tue, Apr 16, 2019 at 4:48 PM Tomas Link <tomaslink at spacesur.com>
>> wrote:
>>> Hi all,
>>> I've just installed successfully GeoNode 2.10rc4 for development.
>>> After running paver start I can enter GeoNode app, and also GeoServer
>>> app if I put the correct URL in the browser. But the comunication between
>>> GeoNode and GeoServer is not working. I cannot see from GeoNode any layers
>>> uploaded, and when I try to enter GeoServer from the link in GeoNode, it
>>> fails to redirect because it's going to port 8000, and GeoServer is in port
>>> 8080.
>>> Is there any proxy configuration for django that i'm missing?
>>> Thanks in advance,
>>> Tomás
>>> Tomás Juan Link
>>> Software Developer
>>> +54 (11) 4342-2976/84
>>> www.spacesur.com
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Tomás Juan Link
> Software Developer
> www.spacesur.com
Tomás Juan Link
Software Developer
www.spacesur.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190416/27ea512f/attachment-0001.html>
More information about the geonode-users
