[GeoNode-users] How to Install The Last Version of GeoNode on a fresh installation of Ubuntu 16.04 without errors: a simple guide/tutorial
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Apr 24 03:29:55 PDT 2019
Uhm, right, Oracle dismissed public support for the JDK recently, so the
docs must be updated. However, GeoServer works with OpenJDK 8 too.
This document
https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
also is a bit old, I only updated the JDK instructions, but should still
work for your purposes.
Please, let me know if you will face issues during the deployment process.
Regards,
Alessio.
Il giorno mer 24 apr 2019 alle ore 10:53 <webmaster at meggiato.com> ha
scritto:
> Dear GeoNode Professionals,
> I'm working for a scientific public body and we'd like to public spatial
> data using geonode.
> I'm trying to install GeoNode on a fresh installation of Ubuntu 16.04.
> I followed all the tutorials on www.geonode.org site and also some video
> tutorials.
> I have tried at least 7 installations without success (GeoNode (v2.10) on
> Docker
> <http://docs.geonode.org/en/latest/tutorials/install_and_admin/running_docker/index.html#running-docker>
> , GeoNode (v2.10) installation on Ubuntu 16.04
> <http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/index.html#geonode-install>
> http://docs.geonode.org/en/latest/tutorials/install_and_admin/quick_install.html#quick-installation
> 1. The Quick Start Intallation on http://geonode.org/#install
> did not work (Tomcat8 is Outdated)
> 2. Similarly the documentation on
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> does not seem updated to the latest versions of the packages (eg Oracle
> Java..)
> The link inside the command (of this tutorial
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html
> is broken:
> django-admin.py startproject --template = *https:
> //github.com/GeoNode/geonode-project/archive/2.8.0.zip
> <http://github.com/GeoNode/geonode-project/archive/2.8.0.zip>* -e py,
> rst, json, yml my_geonode
> 3. Even testing the installation with docker .. I could not get a working
> installation of GeoNode. This is frustrating..
> *I kindly ask the developers of this excellent product which guide* /
> tutorial / book *is available t*o perform a *complete and working
> installation* (with updated packages to date) of the *last version of
> GeoNode on Ubuntu 16.04* without errors.
> Thank you for your kind attention and for the support in advance.
> Alessandro (Venice).
> Salve.
> Sto cercando di installare GeoNode su una fresh installation di Ubuntu
> 16.04.
> Ho seguito tutti i tutorials presenti sul sito www.geonode.org ed anche
> alcuni video tutorials.
> Ho provato almeno 7 installazioni senza successo.
> 1. Anche la Quick Start Intallation su http://geonode.org/#install
> non ha funzionato (Tomcat8 è Outdated )
> 2. Analogamente la documentazione su
> non pare aggiornata alle ultime versioni dei pacchetti (es. Java..)
> Il link presente nel successivo comando (di questo tutorial
> non è disponibile:
> django-admin.py startproject --template=
> https://github.com/GeoNode/geonode-project/archive/2.8.0.zip -e
> py,rst,json,yml my_geonode
> 3. Anche testando l'installazione con docker.. non sono riuscito a
> giungere ad una installazione funzionante di GeoNode.
> Chiedo cortesemente agli sviluppatori di questo eccellente prodotto quale
> guida/tutorial/libro sia disponibile per eseguire una installazione
> completa e funzionante (con pacchetti aggiornati ad oggi) dell'ultima
> versione di GeoNode su Ubuntu 16.04 senza incorrere in errori.
> Ringrazio per la cortese attenzione ed anticipatamente per il supporto.
> Alessandro.
> Le informazioni contenute in questo messaggio sono riservate e
> confidenziali ed è vietata la diffusione in qualunque modo eseguita. Nel
> caso in cui sia stato ricevuto questo messaggio di posta elettronica per
> errore, siete pregati di segnalarlo immediatamente al mittente e
> distruggere quanto ricevuto (compresi i file allegati) senza farne copia.
> Qualsivoglia utilizzo non autorizzato del contenuto di questo messaggio
> costituisce violazione dell'obbligo di non prendere cognizione della
> corrispondenza tra altri soggetti, salvo più grave illecito, ed espone il
> responsabile alle relative conseguenze. (rif. D.L. 196/2003) The content of
> this message may contain confidential information any use, distribution,
> reproduction or disclosure by any other person is strictly prohibited. If
> you have received this e-mail in error, please notify the sender by
> replying to this e-mail and destroy the original transmission and its
> attachments without reading or saving it in any manner. Any unauthorized
> use of the present e-mail amounts to violation of the duty of not reading
> the e-mails exchange among third parties, or even a more serious offence,
> and exposes the responsible to the related consequences. (ref. D.L.
> 196/2003)
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190424/bab68ac0/attachment.html>
More information about the geonode-users
