[GeoNode-users] Geoserver authentication failed after updating IP address
Ran L. kula009 at gmail.com
Wed Apr 24 10:50:18 PDT 2019
Hello all,
I'm trying to install GeoNode using docker by following instructions
provide on https://github.com/GeoNode/geonode-project
After setting up the GeoNode successfully on my machine (a ubuntu 16.04 on
virtual box), I wanted to try updating the IP address by replacing every
"localhost" with "127.0.0.1" in docker-compose.override.yml. .
I followed the exact step specified in:
https://github.com/GeoNode/geonode-project#if-you-want-to-run-the-instance-on-a-public-site
After updating the IP address, I cannot using the quick authentication to
log in to the Geoserver, as the picture shows:
[image: 0.PNG]
The error message I got was "Error: invalid_request: Mismatching redirect
URL."
[image: 1.PNG]
It seems that something went wrong when updating the IP address.
I tried to revert the changes, by replacing "127.0.0.1" with "localhost" in
docker-compose.override.yml.  . But I couldn't get the quick authentication
work anymore. The error message I got is:
[image: 2.PNG]
It seems that the IP address wasn't updated completely, because it still
shows "127.0.0.1", but I already fixed everything in
This is a very critical step I must figure out, as eventually I need to
update the IP address when publishing the services on my server.
Any help is appreciated!
Thank you!
Regards,
Ran
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190424/f84309e0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190424/f84309e0/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190424/f84309e0/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190424/f84309e0/attachment-0005.png>
More information about the geonode-users mailing list
