[GeoNode-users] Geoserver authentication failed after updating IP address
1520 gis
juliermeopensourcedeveloper at gmail.com
Thu Apr 25 06:07:44 PDT 2019
Hi Ran
First of all, the host IP 127.0.0.1 is the same as localhost, now, see if
your your docker-compose.override.yml is set as shown bellow:
version: '2.2'
services:
django:
environment:
DEBUG: 'True'
GEONODE_LB_HOST_IP: 192.168.0.2
GEONODE_LB_PORT: 80
SITEURL: http://192.168.0.2/
ALLOWED_HOSTS: "['192.168.0.2', '127.0.0.1']"
GEOSERVER_PUBLIC_LOCATION: http://192.168.0.2/geoserver/
celery:
environment:
DEBUG: 'True'
GEONODE_LB_PORT: 80
geoserver:
environment:
GEONODE_LB_PORT: 80
NGINX_BASE_URL:
I hope it helps
Kind regards
Julierme
On Wed, Apr 24, 2019 at 2:50 PM Ran L. <kula009 at gmail.com> wrote:
> Hello all,
> I'm trying to install GeoNode using docker by following instructions
> provide on https://github.com/GeoNode/geonode-project
> After setting up the GeoNode successfully on my machine (a ubuntu 16.04 on
> virtual box), I wanted to try updating the IP address by replacing every
> "localhost" with "127.0.0.1" in docker-compose.override.yml. .
> I followed the exact step specified in:
> https://github.com/GeoNode/geonode-project#if-you-want-to-run-the-instance-on-a-public-site
> After updating the IP address, I cannot using the quick authentication to
> log in to the Geoserver, as the picture shows:
> [image: 0.PNG]
> The error message I got was "Error: invalid_request: Mismatching redirect
> URL."
> [image: 1.PNG]
> It seems that something went wrong when updating the IP address.
> I tried to revert the changes, by replacing "127.0.0.1" with "localhost"
> in docker-compose.override.yml. . But I couldn't get the quick
> authentication work anymore. The error message I got is:
> [image: 2.PNG]
> It seems that the IP address wasn't updated completely, because it still
> shows "127.0.0.1", but I already fixed everything in
> This is a very critical step I must figure out, as eventually I need to
> update the IP address when publishing the services on my server.
> Any help is appreciated!
> Thank you!
> Regards,
> Ran
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/cd21cad9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/cd21cad9/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/cd21cad9/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/cd21cad9/attachment-0005.png>
More information about the geonode-users
