[GeoNode-users] Geoserver authentication failed after updating IP address
1520 gis juliermeopensourcedeveloper at gmail.com
Thu Apr 25 06:09:32 PDT 2019
And change HOST_IP: 192.168.0.2  to HOST_IP: your.ip.add.here
Kind regards
Julierme
On Thu, Apr 25, 2019 at 10:07 AM 1520 gis <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Ran
> First of all, the host IP 127.0.0.1 is the same as localhost, now, see if
> your your docker-compose.override.yml is set as shown bellow:
> version: '2.2'
> services:
>   django:
>     environment:
>       DEBUG: 'True'
>       GEONODE_LB_HOST_IP: 192.168.0.2
>       GEONODE_LB_PORT: 80
>       SITEURL: http://192.168.0.2/
>       ALLOWED_HOSTS: "['192.168.0.2', '127.0.0.1']"
>       GEOSERVER_PUBLIC_LOCATION: http://192.168.0.2/geoserver/
>   celery:
>     environment:
>       DEBUG: 'True'
>       GEONODE_LB_PORT: 80
>   geoserver:
>     environment:
>       GEONODE_LB_PORT: 80
>       NGINX_BASE_URL:
> I hope it helps
> Kind regards
> Julierme
> On Wed, Apr 24, 2019 at 2:50 PM Ran L. <kula009 at gmail.com> wrote:
>> Hello all,
>> I'm trying to install GeoNode using docker by following instructions
>> provide on https://github.com/GeoNode/geonode-project
>> After setting up the GeoNode successfully on my machine (a ubuntu 16.04
>> on virtual box), I wanted to try updating the IP address by replacing every
>> "localhost" with "127.0.0.1" in docker-compose.override.yml. .
>> I followed the exact step specified in:
>> https://github.com/GeoNode/geonode-project#if-you-want-to-run-the-instance-on-a-public-site
>> After updating the IP address, I cannot using the quick authentication to
>> log in to the Geoserver, as the picture shows:
>> [image: 0.PNG]
>> The error message I got was "Error: invalid_request: Mismatching
>> redirect URL."
>> [image: 1.PNG]
>> It seems that something went wrong when updating the IP address.
>> I tried to revert the changes, by replacing "127.0.0.1" with "localhost"
>> in docker-compose.override.yml.  . But I couldn't get the quick
>> authentication work anymore. The error message I got is:
>> [image: 2.PNG]
>> It seems that the IP address wasn't updated completely, because it still
>> shows "127.0.0.1", but I already fixed everything in
>> This is a very critical step I must figure out, as eventually I need to
>> update the IP address when publishing the services on my server.
>> Any help is appreciated!
>> Thank you!
>> Regards,
>> Ran
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/fc151af9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/fc151af9/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/fc151af9/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190425/fc151af9/attachment-0005.png>
More information about the geonode-users mailing list
