[GeoNode-users] GeoNode questions
Simone Giannecchini simone.giannecchini at geo-solutions.it
Tue Apr 30 11:05:22 PDT 2019
Hi Magnus,
someone else already answered in a separate email.
Anyway, shortly we will switch the master demo to use MapStore, hence
you might want to recheck it and see how it goes.
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Tue, Apr 23, 2019 at 2:20 PM Magnus Nilsson <johnrobot at gmail.com> wrote:
> Hi
> I have had a quick look at using GeoNode as an SDI tool for our organization and I have a few initial questions:
> The web maps don´t seem to work well on mobile clients. Very small buttons and trouble zooming, for example. Is that being worked on? I tried with Firefox on my S9.
> Is it correct that GeoNode does not support uploading GeoPackage files? We use this format quite a lot for our geodata and going back to SHP seems like a step in the wrong direction.
> When uploading a data set, I get an option for creating metadata. Can this step be made mandatory (including defining the mandatory fields)? I would like to avoid setting up an environment where users upload data sets, but skip the metadata step.
> When choosing to create a map from a layer, the view is not centered on the data set. Wouldn´t this be more useful?
> When I click ”Zoom To Max Extent”, the map zooms out to the whole globe (even without a background map selected). Wouldn´t it be more useful to zoom out to the extent of the data added by the user?
> The ”Get Feature Info” tool doesn´t close the previous pop up window(s) when clicking again, so I can quickly get 5-10 windows blocking the map. Is this a known issue?
> Using the same tool, I noticed that Swedish characters (å/ä/ö) in attribute values do not work, using UTF-8 encoding.
> I noticed that the translation to Swedish is incomplete and sometimes misleading. Is the latest translation pulled from Transifex for each official release?
> I used http://master.demo.geonode.org/ for my tests.
> Regards,
> Magnus
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
