[GeoNode-users] Base Administration is Empty
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Aug 21 00:38:40 PDT 2019
it looks like you are missing some initialization scripts.
Please read carefully this section:
http://docs.geonode.org/en/2.10.x/install/core/index.html#run-geonode-for-the-first-time-in-debug-mode
If you want to translate the categories names and descriptions, please
follow this guide:
http://docs.geonode.org/en/2.10.x/contribute/translation/index.html
Il giorno mar 20 ago 2019 alle ore 23:20 Frederico dos Santos Soares <
fssunb at gmail.com> ha scritto:
> Hi everybody.
> I think that I have an issue with Base Administration.
> In this url
> https://doc-geonode.readthedocs.io/en/latest/004_admin_workshop/001_admin_panel/base.html
> All the metadata categorys are complete, but in my Geonode's instalation
> they are empty, including the database tables.
> Do I made something wrong in the instalation? Do I have to insert all
> metadata categorys by myself?
> My objectve is use ISO standards in portuguese.
> Can anyone help me?
> I'm using Geonode versão 2.10.1 In CentOS.
> My Best Regards
> Geógrafo
> 55 61 8416 0105
> fssunb at gmail.com
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190821/47af249b/attachment.html>
More information about the geonode-users
