[GeoNode-users] (no subject)
Amedeo Fadini
amefad at gmail.com
Mon Aug 26 07:47:30 PDT 2019
Hello Deb,
we still need more informations... what error page is shown on the browser?
the netstat -a output is fine for postgres, it says that the daemon
acccepts connection over IPV4 and IPV6
It's a bit strange that is not the same for apache and tomcat7 seems that
they are listening only on IPV6 address... maybe some update has changed
network config system wide? Are you the only administrator of thata server?
We assume that the installation is in dev mode or non docker:
are you able to test geonode and geoserver from the server with addresses
localhost and localhost:8080/geoserver?
If you don't have X forwarding you can try this using a textual browser
like lynx just to test (you'll receive a "javascript error page" for
geoserver)
Amedeo
Il giorno lun 26 ago 2019 alle ore 15:55 Dev Gis <deviirmr at gmail.com> ha
scritto:
> Also, it seems two Postgres instance
> On Mon, Aug 26, 2019 at 2:14 PM Dev Gis <deviirmr at gmail.com> wrote:
>> Thank you, Toni, for coming to help.
>> here is the log, also I have attaced a full log.
>> gridanode at geomaster:~$ tail -f /var/log/apache2/error.log
>> [Mon Aug 26 10:40:14.060522 2019] [mpm_event:notice] [pid 1399:tid
>> 139950362343296] AH00491: caught
>> SIGTERM, shutting down
>> [Mon Aug 26 10:40:15.127018 2019] [wsgi:warn] [pid 27028:tid
>> 140521999849344] mod_wsgi: Compiled for
>> Python/2.7.11.
>> [Mon Aug 26 10:40:15.127063 2019] [wsgi:warn] [pid 27028:tid
>> 140521999849344] mod_wsgi: Runtime usin
>> g Python/2.7.12.
>> [Mon Aug 26 10:40:15.129544 2019] [mpm_event:notice] [pid 27028:tid
>> 140521999849344] AH00489: Apache
>> /2.4.18 (Ubuntu) mod_wsgi/4.3.0 Python/2.7.12 configured
>> -- resuming normal operations
>> [Mon Aug 26 10:40:15.129573 2019] [core:notice] [pid 27028:tid
>> 140521999849344] AH00094: Command lin
>> e: '/usr/sbin/apache2'
>> [Mon Aug 26 11:58:46.196632 2019] [mpm_event:notice] [pid 27028:tid
>> 140521999849344] AH00491: caught
>> [Mon Aug 26 11:58:47.299060 2019] [wsgi:warn] [pid 28020:tid
>> 139930662770560] mod_wsgi: Compiled for
>> Python/2.7.11.
>> [Mon Aug 26 11:58:47.299145 2019] [wsgi:warn] [pid 28020:tid
>> 139930662770560] mod_wsgi: Runtime usin
>> g Python/2.7.12.
>> [Mon Aug 26 11:58:47.303404 2019] [mpm_event:notice] [pid 28020:tid
>> 139930662770560] AH00489: Apache
>> [Mon Aug 26 11:58:47.303461 2019] [core:notice] [pid 28020:tid
>> 139930662770560] AH00094: Command lin
>> Regards
>> Deb
>> On Mon, Aug 26, 2019 at 12:06 PM Toni Schönbuchner <
>> toni.schoenbuchner at csgis.de> wrote:
>>> Hi Deb,
>>> (please add a subject to your mails)
>>> what errors do you see in browser?
>>> what errors do you see in logs? (f.e. /var/log/apache2/error.log if on
>>> manual install with apache)
>>> can you tell us more about your setup? docker/non docker, version?
>>> Cheers,
>>> Toni
>>> CSGIS
>>> Gottschedstraße 12
>>> 04109 Leipzig
>>> Telefon 0341. 39 37 3397
>>> Web https://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> Am 26.08.2019 um 11:46 schrieb Dev Gis <deviirmr at gmail.com>:
>>> Hello,
>>> Everything was fine a week ago but suddenly GeoNode stops working and
>>> inaccessible by IP, what else I need to check, any suggestion, please.
>>> I run following command seems not issue
>>> ' gridanode at geomaster:~$ sudo /etc/init.d/apache2 restart
>>> [ ok ] Restarting apache2 (via systemctl): apache2.service.
>>> gridanode at geomaster:~$ sudo /etc/init.d/tomcat7 restart
>>> [ ok ] Restarting tomcat7 (via systemctl): tomcat7.service. '
>>> also, I run and seems no issue
>>> gridanode at geomaster:~$ Sudo geonode check
>>> System check identified no issues (2 silenced).
>>> Regards
>>> Deb
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190826/d3ca6bd0/attachment.html>
More information about the geonode-users
