[GeoNode-users] (no subject)
Dev Gis
deviirmr at gmail.com
Tue Aug 27 06:28:05 PDT 2019
Hi Amedeo,
1. Browser load nothing, I mean it's inaccessible by IP
http://82.116.78.168/
2. Do you think netstat -a looks normal
gridanode at geomaster:~/docker_system_file/testdocs$ netstat -a
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 *:ssh *:* LISTEN
tcp 0 0 localhost:postgresql *:* LISTEN
tcp 0 0 hisoya.grida.no:ssh 10.2.101.190:56373
ESTABLISHED
tcp 0 0 hisoya.grida.no:ssh 10.2.101.190:56379
ESTABLISHED
tcp 0 0 localhost:postgresql localhost:33150
ESTABLISHED
tcp 0 0 hisoya.grida.no:ssh 10.2.101.190:55895
ESTABLISHED
tcp6 0 0 [::]:http-alt [::]:* LISTEN
tcp6 0 0 [::]:http [::]:* LISTEN
tcp6 0 0 [::]:5555 [::]:* LISTEN
tcp6 0 0 [::]:ssh [::]:* LISTEN
tcp6 0 0 localhost:postgresql [::]:* LISTEN
tcp6 0 0 localhost:8005 [::]:* LISTEN
tcp6 0 0 [::]:8006 [::]:* LISTEN
tcp6 0 0 localhost:33150 localhost:postgresql
ESTABLISHED
udp6 0 0 localhost:56119 localhost:56119
ESTABLISHED
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ] DGRAM 44535
/run/user/1000/systemd/notify
unix 2 [ ACC ] STREAM LISTENING 44536
/run/user/1000/systemd/private
unix 2 [ ACC ] SEQPACKET LISTENING 10560 /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 17944
/run/containerd/containerd.sock
unix 2 [ ACC ] STREAM LISTENING 17999
/var/run/docker/metrics.sock
unix 2 [ ACC ] STREAM LISTENING 10546
/run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 10550
/run/systemd/fsck.progress
unix 2 [ ACC ] STREAM LISTENING 18457
/run/docker/libnetwork/d70e8ad27924b3045866646a3
e8aab4408cde066ffac8527dff9237969bf6032.sock
unix 2 [ ACC ] STREAM LISTENING 10559
/run/lvm/lvmetad.socket
unix 2 [ ACC ] STREAM LISTENING 10561
/run/lvm/lvmpolld.socket
unix 2 [ ACC ] STREAM LISTENING 10562
/run/systemd/journal/stdout
unix 8 [ ] DGRAM 10563
/run/systemd/journal/socket
unix 2 [ ] DGRAM 10790
/run/systemd/journal/syslog
unix 11 [ ] DGRAM 10830
/run/systemd/journal/dev-log
unix 2 [ ACC ] STREAM LISTENING 43375
@/containerd-shim/moby/a41c957ce2008e63632d74757
8017861b82c872f5111a6cda1f2c79e592c6f42/shim.sock
unix 2 [ ACC ] STREAM LISTENING 33528
/var/run/apache2/wsgi.1901.1.1.sock
unix 2 [ ACC ] STREAM LISTENING 19470
/tmp/.java_pid2064.tmp
unix 2 [ ACC ] STREAM LISTENING 52597
@/containerd-shim/moby/868eae8820b0db4ca7993adbc
b6cb8982595cb17c002a492308469a026de630d/shim.sock
unix 2 [ ACC ] STREAM LISTENING 13500
/var/lib/lxd/unix.socket
unix 2 [ ACC ] STREAM LISTENING 15791
@ISCSIADM_ABSTRACT_NAMESPACE
unix 2 [ ACC ] STREAM LISTENING 13485
/run/uuidd/request
unix 2 [ ACC ] STREAM LISTENING 13486
/var/run/docker.sock
unix 2 [ ACC ] STREAM LISTENING 13487 /run/snapd.socket
unix 2 [ ACC ] STREAM LISTENING 13488
/run/snapd-snap.socket
unix 2 [ ACC ] STREAM LISTENING 13507 /run/acpid.socket
unix 2 [ ACC ] STREAM LISTENING 13508
/var/run/dbus/system_bus_socket
unix 3 [ ] DGRAM 10545
/run/systemd/notify
unix 2 [ ACC ] STREAM LISTENING 14862
/var/run/postgresql/.s.PGSQL.5432
unix 3 [ ] STREAM CONNECTED 16952
unix 3 [ ] STREAM CONNECTED 12716
unix 2 [ ] DGRAM 103080
unix 3 [ ] STREAM CONNECTED 15185
unix 2 [ ] DGRAM 12754
unix 2 [ ] DGRAM 15783
unix 3 [ ] STREAM CONNECTED 52603
unix 3 [ ] STREAM CONNECTED 18129
unix 2 [ ] DGRAM 15875
unix 3 [ ] STREAM CONNECTED 14526
unix 3 [ ] STREAM CONNECTED 14378
unix 3 [ ] STREAM CONNECTED 13792
unix 2 [ ] DGRAM 47202
unix 2 [ ] STREAM CONNECTED 19474
unix 3 [ ] STREAM CONNECTED 14792
unix 3 [ ] STREAM CONNECTED 14153
unix 3 [ ] STREAM CONNECTED 13793
unix 2 [ ] DGRAM 103199
unix 2 [ ] STREAM CONNECTED 20064
unix 3 [ ] DGRAM 12765
unix 3 [ ] STREAM CONNECTED 103116
unix 3 [ ] STREAM CONNECTED 16963
unix 2 [ ] DGRAM 14019
unix 3 [ ] STREAM CONNECTED 14791
unix 3 [ ] STREAM CONNECTED 103117
unix 3 [ ] STREAM CONNECTED 14525
unix 3 [ ] DGRAM 12762
unix 3 [ ] DGRAM 12764
unix 2 [ ] DGRAM 18143
unix 3 [ ] STREAM CONNECTED 15184
unix 3 [ ] STREAM CONNECTED 52601
unix 3 [ ] STREAM CONNECTED 14529
unix 3 [ ] STREAM CONNECTED 12715
unix 3 [ ] STREAM CONNECTED 14516
unix 2 [ ] DGRAM 11208
unix 3 [ ] STREAM CONNECTED 43379
unix 3 [ ] STREAM CONNECTED 14471
unix 3 [ ] STREAM CONNECTED 14528
unix 3 [ ] DGRAM 12763
unix 3 [ ] STREAM CONNECTED 13852
unix 3 [ ] STREAM CONNECTED 13853
unix 3 [ ] STREAM CONNECTED 13590
unix 2 [ ] DGRAM 14522
unix 3 [ ] STREAM CONNECTED 43381
unix 3 [ ] STREAM CONNECTED 103235
unix 3 [ ] STREAM CONNECTED 14158
unix 2 [ ] DGRAM 44519
unix 3 [ ] STREAM CONNECTED 13591
unix 3 [ ] STREAM CONNECTED 18128
unix 3 [ ] STREAM CONNECTED 103236
unix 3 [ ] STREAM CONNECTED 18010
unix 3 [ ] STREAM CONNECTED 11285
unix 3 [ ] STREAM CONNECTED 15570
unix 3 [ ] STREAM CONNECTED 11284
unix 3 [ ] STREAM CONNECTED 47239
unix 3 [ ] STREAM CONNECTED 18006
unix 3 [ ] STREAM CONNECTED 15569
unix 3 [ ] STREAM CONNECTED 11529
unix 3 [ ] STREAM CONNECTED 15669
unix 3 [ ] STREAM CONNECTED 44499
unix 3 [ ] DGRAM 11570
unix 3 [ ] STREAM CONNECTED 47240
unix 3 [ ] STREAM CONNECTED 14527
unix 3 [ ] STREAM CONNECTED 14438
unix 3 [ ] STREAM CONNECTED 18009
unix 3 [ ] STREAM CONNECTED 14379
unix 2 [ ] DGRAM 11557
unix 3 [ ] STREAM CONNECTED 18007
unix 3 [ ] STREAM CONNECTED 14440
unix 3 [ ] STREAM CONNECTED 14439
unix 3 [ ] DGRAM 11569
unix 3 [ ] STREAM CONNECTED 15670
unix 3 [ ] STREAM CONNECTED 11535
unix 2 [ ] DGRAM 44497
unix 3 [ ] STREAM CONNECTED 44491
unix 2 [ ] DGRAM 17947
unix 2 [ ] DGRAM 14314
unix 2 [ ] DGRAM 11199
3. Yes, I am the administrator for the current server. In past, I was
trying to open some ports for docker but not sure how it affects the GeoNode
4. GeoNode is not installed in docker. But this machine has docker with a
different purpose
5 I can CURL the Geonode website and GeoServer on the local machine and
it's accessible
I am using GeoNode 2.6 on ubuntu 16.
I feel that I have missed the TCP/IP configuration of ubuntu while fixing
port for docker container, but now is there any way to reset network or any
suggestion?
Regards
Deb
On Mon, Aug 26, 2019 at 4:47 PM Amedeo Fadini <amefad at gmail.com> wrote:
> Hello Deb,
> we still need more informations... what error page is shown on the browser?
> the netstat -a output is fine for postgres, it says that the daemon
> acccepts connection over IPV4 and IPV6
> It's a bit strange that is not the same for apache and tomcat7 seems that
> they are listening only on IPV6 address... maybe some update has changed
> network config system wide? Are you the only administrator of thata server?
> We assume that the installation is in dev mode or non docker:
> are you able to test geonode and geoserver from the server with addresses
> localhost and localhost:8080/geoserver?
> If you don't have X forwarding you can try this using a textual browser
> like lynx just to test (you'll receive a "javascript error page" for
> geoserver)
> Amedeo
> Il giorno lun 26 ago 2019 alle ore 15:55 Dev Gis <deviirmr at gmail.com> ha
> scritto:
>> Also, it seems two Postgres instance
>> On Mon, Aug 26, 2019 at 2:14 PM Dev Gis <deviirmr at gmail.com> wrote:
>>> Thank you, Toni, for coming to help.
>>> here is the log, also I have attaced a full log.
>>> gridanode at geomaster:~$ tail -f /var/log/apache2/error.log
>>> [Mon Aug 26 10:40:14.060522 2019] [mpm_event:notice] [pid 1399:tid
>>> 139950362343296] AH00491: caught
>>> SIGTERM, shutting down
>>> [Mon Aug 26 10:40:15.127018 2019] [wsgi:warn] [pid 27028:tid
>>> 140521999849344] mod_wsgi: Compiled for
>>> Python/2.7.11.
>>> [Mon Aug 26 10:40:15.127063 2019] [wsgi:warn] [pid 27028:tid
>>> 140521999849344] mod_wsgi: Runtime usin
>>> g Python/2.7.12.
>>> [Mon Aug 26 10:40:15.129544 2019] [mpm_event:notice] [pid 27028:tid
>>> 140521999849344] AH00489: Apache
>>> /2.4.18 (Ubuntu) mod_wsgi/4.3.0 Python/2.7.12 configured
>>> -- resuming normal operations
>>> [Mon Aug 26 10:40:15.129573 2019] [core:notice] [pid 27028:tid
>>> 140521999849344] AH00094: Command lin
>>> e: '/usr/sbin/apache2'
>>> [Mon Aug 26 11:58:46.196632 2019] [mpm_event:notice] [pid 27028:tid
>>> 140521999849344] AH00491: caught
>>> [Mon Aug 26 11:58:47.299060 2019] [wsgi:warn] [pid 28020:tid
>>> 139930662770560] mod_wsgi: Compiled for
>>> Python/2.7.11.
>>> [Mon Aug 26 11:58:47.299145 2019] [wsgi:warn] [pid 28020:tid
>>> 139930662770560] mod_wsgi: Runtime usin
>>> g Python/2.7.12.
>>> [Mon Aug 26 11:58:47.303404 2019] [mpm_event:notice] [pid 28020:tid
>>> 139930662770560] AH00489: Apache
>>> [Mon Aug 26 11:58:47.303461 2019] [core:notice] [pid 28020:tid
>>> 139930662770560] AH00094: Command lin
>>> Regards
>>> Deb
>>> On Mon, Aug 26, 2019 at 12:06 PM Toni Schönbuchner <
>>> toni.schoenbuchner at csgis.de> wrote:
>>>> Hi Deb,
>>>> (please add a subject to your mails)
>>>> what errors do you see in browser?
>>>> what errors do you see in logs? (f.e. /var/log/apache2/error.log if on
>>>> manual install with apache)
>>>> can you tell us more about your setup? docker/non docker, version?
>>>> Cheers,
>>>> Toni
>>>> CSGIS
>>>> Gottschedstraße 12
>>>> 04109 Leipzig
>>>> Telefon 0341. 39 37 3397
>>>> Web https://csgis.de
>>>> Hinweis gemäß § 33 BDSG
>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>>> ausschließlich für den
>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>> diese E-Mail versehentlich
>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>> löschen Sie diese Nachricht
>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>> Vervielfältigung, Veränderung,
>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>> Am 26.08.2019 um 11:46 schrieb Dev Gis <deviirmr at gmail.com>:
>>>> Hello,
>>>> Everything was fine a week ago but suddenly GeoNode stops working and
>>>> inaccessible by IP, what else I need to check, any suggestion, please.
>>>> I run following command seems not issue
>>>> ' gridanode at geomaster:~$ sudo /etc/init.d/apache2 restart
>>>> [ ok ] Restarting apache2 (via systemctl): apache2.service.
>>>> gridanode at geomaster:~$ sudo /etc/init.d/tomcat7 restart
>>>> [ ok ] Restarting tomcat7 (via systemctl): tomcat7.service. '
>>>> also, I run and seems no issue
>>>> gridanode at geomaster:~$ Sudo geonode check
>>>> System check identified no issues (2 silenced).
>>>> Regards
>>>> Deb
>>>> _______________________________________________
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190827/e247824e/attachment-0001.html>
More information about the geonode-users
