[GeoNode-users] FW: Geoserver problem deploying spcgeonode with docker over https behind reverse proxy
Silvia Salsone
salsone at planetek.it
Thu Dec 12 04:04:21 PST 2019
Hi all,
I've deployed an spcgeonode with docker, with the following settings:
HTTPS_HOST=my_host
HTTPS_PORT=443
specified in the .env file, as required.
I managed to correctly link Geonode to Geoserver using https calls, getting access to it using the Geonode login button (the single sign-on feature).
But the issue seems to be inside the Geoserver application, where I get the following error when I click on "Submit" or "Cancel" inside any Geoserver page (i.e. in Global Settings page as in the image below).
[cid:image001.jpg at 01D5B0E9.334D7340]
Thus, it seems local Geoserver calls fail!
Does anyone have an idea of why I get this error? Can it be I miss anything on Geoserver setting files? Or is it a proxy issue?
Thank you in advance for any helpful suggestion.
Best wishes,
Teresa
Teresa Fazio
Technical Specialist
Government & Security SBU
Planetek Italia S.r.l.
Via Massaua, 12
I-70132 Bari BA - Italy
Tel. +39 080 9644200
fazio at planetek.it<mailto:fazio at planetek.it>
http://www.planetek.it<http://www.planetek.it/>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191212/d1d37b2f/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191212/d1d37b2f/attachment-0001.jpg>
More information about the geonode-users
