[GeoNode-users] FW: Geoserver problem deploying spcgeonode with docker over https behind reverse proxy
Francesco Bartoli xbartolone at gmail.com
Fri Dec 13 03:28:09 PST 2019
Hi Silvia,
any chance to have the output from the log of the geoserver container? It would help
Thanks,
Francesco
Il 12 dic 2019, 13:04 +0100, Silvia Salsone <salsone at planetek.it>, ha scritto:
> Hi all,
> I’ve deployed an spcgeonode with docker, with the following settings:
> HTTPS_HOST=my_host
> HTTPS_PORT=443
> specified in the .env file, as required.
> I managed to correctly link Geonode to Geoserver using https calls, getting access to it using the Geonode login button (the single sign-on feature).
> But the issue seems to be inside the Geoserver application, where I get the following error when I click on “Submit” or “Cancel” inside any Geoserver page (i.e. in Global Settings page as in the image below).
> <image001.jpg>
> Thus, it seems local Geoserver calls fail!
> Does anyone have an idea of why I get this error? Can it be I miss anything on Geoserver setting files? Or is it a proxy issue?
> Thank you in advance for any helpful suggestion.
> Best wishes,
> Teresa
> Teresa Fazio
> Technical Specialist
> Government & Security SBU
> Planetek Italia S.r.l.
> Via Massaua, 12
> I-70132 Bari BA - Italy
> Tel. +39 080 9644200
> fazio at planetek.it
> http://www.planetek.it
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191213/a19b545c/attachment.html>
More information about the geonode-users mailing list
