[GeoNode-users] FW: Geoserver problem deploying spcgeonode with docker over https behind reverse proxy
Silvia Salsone
salsone at planetek.it
Fri Dec 13 06:05:24 PST 2019
Hi Francesco, hi all,
We’ve just found these pages explaining and solving our issue:
https://osgeo-org.atlassian.net/browse/GEOS-9353?inbox=true&=
https://docs.geoserver.org/stable/en/user/security/webadmin/csrf.html
It wasn’t easy to find the right configuration. It would be great to add it to the main documentation, since I believe it must be a common issue.
Thanks for you support,
Silvia
From: Francesco Bartoli [mailto:xbartolone at gmail.com]
Sent: venerdì 13 dicembre 2019 12:28
To: geonode-users at lists.osgeo.org; Silvia Salsone <salsone at planetek.it>
Subject: Re: [GeoNode-users] FW: Geoserver problem deploying spcgeonode with docker over https behind reverse proxy
Hi Silvia,
any chance to have the output from the log of the geoserver container? It would help
Thanks,
Francesco
Il 12 dic 2019, 13:04 +0100, Silvia Salsone <salsone at planetek.it<mailto:salsone at planetek.it>>, ha scritto:
Hi all,
I’ve deployed an spcgeonode with docker, with the following settings:
HTTPS_HOST=my_host
HTTPS_PORT=443
specified in the .env file, as required.
I managed to correctly link Geonode to Geoserver using https calls, getting access to it using the Geonode login button (the single sign-on feature).
But the issue seems to be inside the Geoserver application, where I get the following error when I click on “Submit” or “Cancel” inside any Geoserver page (i.e. in Global Settings page as in the image below).
<image001.jpg>
Thus, it seems local Geoserver calls fail!
Does anyone have an idea of why I get this error? Can it be I miss anything on Geoserver setting files? Or is it a proxy issue?
Thank you in advance for any helpful suggestion.
Best wishes,
Teresa
Teresa Fazio
Technical Specialist
Government & Security SBU
Planetek Italia S.r.l.
Via Massaua, 12
I-70132 Bari BA - Italy
Tel. +39 080 9644200
fazio at planetek.it<mailto:fazio at planetek.it>
http://www.planetek.it<http://www.planetek.it/>
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191213/888e1656/attachment-0001.html>
More information about the geonode-users
