[GeoNode-users] Permissions - Cannot download layers
Paolo Pasquali paolo.pasquali at gmail.com
Mon Dec 16 00:50:19 PST 2019
Ciao Alessio,
Thanks for the reply.
I've already followed this documentation section but without success.
If I run:
python manage.py sync_geonode_layers --updatepermissions
I get:
manage.py sync_geonode_layers: error: argument --updatepermissions:
expected one argument
Which argument should I specify?
Thanks,
P.
On Mon, Dec 16, 2019 at 9:38 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hello Paolo,
> probably this section of the docs might be helpful
> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#update-permissions-metadata-legends-and-download-links
> Il giorno ven 13 dic 2019 alle ore 17:05 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Dear all,
>> I'm still struggling with the permission system (again).
>> I have migrated several layers from an old version into a GeoNode 2.10. I
>> have launched the updatelayers and sync_geonode_layers commands but for all
>> these layers I have the "Request Download" button instead of the "Download
>> Layer" button.
>> The problem is that my user is administrator and "Anyone" is flagged for
>> "Who can download this layer?" in the permission modal.
>> Could you suggest how to fix this issue?
>> Please note that some commands mentioned in the docs such as
>> set_layer_permissions are not available in my 2.10 version.
>> If I upload a new layer everything is fine.
>> Thanks.
>> Best,
>> Paolo
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/e922d2e1/attachment-0001.html>
More information about the geonode-users mailing list
