[GeoNode-users] Permissions - Cannot download layers
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Dec 16 01:41:24 PST 2019
Uhm,
I don't get this message. Just tried to run the command and it started
scanning the layers. Which version are you using?
Moreover, if you want to batch set/unset the permissions you might want to
consider also this command here
http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#batch-sync-permissions
I'm using 2.10.x branch now.
Il giorno lun 16 dic 2019 alle ore 09:50 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Alessio,
> Thanks for the reply.
> I've already followed this documentation section but without success.
> If I run:
> python manage.py sync_geonode_layers --updatepermissions
> I get:
> manage.py sync_geonode_layers: error: argument --updatepermissions:
> expected one argument
> Which argument should I specify?
> Thanks,
> P.
> On Mon, Dec 16, 2019 at 9:38 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello Paolo,
>> probably this section of the docs might be helpful
>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#update-permissions-metadata-legends-and-download-links
>> Il giorno ven 13 dic 2019 alle ore 17:05 Paolo Pasquali <
>>> Dear all,
>>> I'm still struggling with the permission system (again).
>>> I have migrated several layers from an old version into a GeoNode 2.10.
>>> I have launched the updatelayers and sync_geonode_layers commands but for
>>> all these layers I have the "Request Download" button instead of the
>>> "Download Layer" button.
>>> The problem is that my user is administrator and "Anyone" is flagged for
>>> "Who can download this layer?" in the permission modal.
>>> Could you suggest how to fix this issue?
>>> Please note that some commands mentioned in the docs such as
>>> set_layer_permissions are not available in my 2.10 version.
>>> If I upload a new layer everything is fine.
>>> Thanks.
>>> Best,
>>> Paolo
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/eda57423/attachment-0001.html>
More information about the geonode-users mailing list
