[GeoNode-users] Permissions - Cannot download layers
Paolo Pasquali paolo.pasquali at gmail.com
Mon Dec 16 02:30:06 PST 2019
Should be 2.10.0 or something like that but less than 2.10.1
For instance, in the Django admin I don't get the "Set Layer permissions"
action from the drop down menu.
Anyway, If I run
python manage.py set_layers_permissions -p download -g SomeGroup
Should the expected result be that all the layers are downloadable for that
group. But it does not seem to work.
Is there a way to set a permission for all the users and not filtered by a
group or user?
Thanks.
Please note that if I upload a new layer, the permissions are properly set.
Ciao
P.
On Mon, Dec 16, 2019 at 10:41 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Uhm,
> I don't get this message. Just tried to run the command and it started
> scanning the layers. Which version are you using?
> Moreover, if you want to batch set/unset the permissions you might want to
> consider also this command here
> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#batch-sync-permissions
> I'm using 2.10.x branch now.
> Il giorno lun 16 dic 2019 alle ore 09:50 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Ciao Alessio,
>> Thanks for the reply.
>> I've already followed this documentation section but without success.
>> If I run:
>> python manage.py sync_geonode_layers --updatepermissions
>> I get:
>> manage.py sync_geonode_layers: error: argument --updatepermissions:
>> expected one argument
>> Which argument should I specify?
>> Thanks,
>> P.
>> On Mon, Dec 16, 2019 at 9:38 AM Alessio Fabiani <
>>> Hello Paolo,
>>> probably this section of the docs might be helpful
>>> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#update-permissions-metadata-legends-and-download-links
>>> Il giorno ven 13 dic 2019 alle ore 17:05 Paolo Pasquali <
>>>> Dear all,
>>>> I'm still struggling with the permission system (again).
>>>> I have migrated several layers from an old version into a GeoNode 2.10.
>>>> I have launched the updatelayers and sync_geonode_layers commands but for
>>>> all these layers I have the "Request Download" button instead of the
>>>> "Download Layer" button.
>>>> The problem is that my user is administrator and "Anyone" is flagged
>>>> for "Who can download this layer?" in the permission modal.
>>>> Could you suggest how to fix this issue?
>>>> Please note that some commands mentioned in the docs such as
>>>> set_layer_permissions are not available in my 2.10 version.
>>>> If I upload a new layer everything is fine.
>>>> Thanks.
>>>> Best,
>>>> Paolo
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191216/dbec1218/attachment-0001.html>
More information about the geonode-users mailing list
